This thread is privately moderated by oldsneakers, who may elect to delete unwanted replies.
Jan 25, 2021, 08:30 PM
oldsneakers's Avatar
Mini-HowTo
Crow on a AR9350
This is one method of setting up Crow on a Spektrum AR9350 receiver and a compatible Spektrum radio, DX9, iX12, iX20 and more. This method of adding Crow is only applicable to the AR9350, AR7350 and the AR636. Although there may not be enough available channels on a AR7350 and AR636. Other Spektrum receivers only need to mix the flaps into the left aileron to work(FLP > LAL).
This information came from RCG member simages. He dug thru the long history of this receiver and figured out how to get this to work.
In the AS3X app, set up the AR9350 as a Flaperon wing type and normal tail type.
In the AS3X app, on the Port Assignment page, set Gear to Port 5 & Aux1 to port 7
Plug these servos into these ports on the AR9350
RAileron - 2
RFlap - 5
LAileron - 6
LFlap - 7
In your transmitter:
Set the wing type to OneAileron and OneFlap
In Channel Assign, Rx Port Assignment.
Set Ports 5 & 6 to Flap
Open the Flap settings. Choose the switch you want to use. Enter some test numbers for Flaps
Turn everything on. Make sure you bound the receiver to the transmitter.
Turn the Flaps switch on. If one of the flaps goes the wrong way, reverse the Flap in the transmitter as shown in the next picture.
The flaps are feeding the ailerons at 100%. The amount of aileron deflection is controlled by the % of flaps. If you want more flap, you can change the max travel of the flaps to increase the flap deployment but the ailerons may max out.
Discussion New AS3X Receivers AR9350, AR7350, AR636 and AR6335 WITH INTEGRATED TELEMETRY ! Mukenukem Radios 12790 Jun 15, 2021 08:19 AM
Discussion Setting up Crow on a DX7s DanF Radios 1 May 25, 2016 11:42 AM
Discussion Crow set up on full house plane. 57sailplane Slope 28 Jan 05, 2016 01:04 PM
Discussion crow on Spektrum DX7? planepainter Electric Sailplanes 2 Nov 19, 2015 05:29 PM
Help! Crow on throttle and throttle on switch on a DX7? hammer833 Electric Sailplanes 14 Jan 20, 2011 02:58 PM
