Jan 24, 2021, 12:32 AM
Question
Radio Master TX16S & OpenTX 2.3.9
Yeap, newbie but I know a little about planes adn flying. Hurting to get the dam ailerons even. When trim the ailerons they both move and I need to trim just one for initial balancing. This is a hobbyking ANX flyer already built and not built well. looking for info on open TX but can't even find a manual. thanks all!
Jan 24, 2021, 06:22 AM
Beach Bum
SteveFlysloco's Avatar
The ailerons are most likely on a Y-harness which operates them together as one channel. To adjust one, use the linkage. The rod that goes from servo to control surface is usually threaded. Unclip it from control surface, screw it in to shorten rod, unscrew to lengthen.
Jan 25, 2021, 04:34 PM
Still circling in sink...
For OpenTx, you have a few choices:
openTx university http://www.open-tx.org/2017/01/24/opentx-university
A lot of the documentation is for older versions but still very relevant. Good place to start.
Look in the Radios forums here on RCG
Enormous amounts of info, but that means you have to sift through enormous amounts of info.
Aloft Hobbies sells a manual https://alofthobbies.com/radio/tx-ge...x-manuals.html
I don't have this so can't comment personally but Aloft has a good reputation.
New Product RadioMaster - TX16S 16Ch 2.4ghz Multi-Protocol OpenTX Radio System Hobby Porter Radios 10545 Today 07:08 AM
Help! Radio master TX16S question Hlosada Radios 13 Aug 23, 2020 06:57 AM
Help! crash with G-RX ACCESS 2.1.0 opentx 2.3.9 and Xlite pro 2.1.0 Djodjo FrSky 8 Aug 04, 2020 12:47 PM
Help! Radio master tx16s fepsphan Radios 6 Jun 09, 2020 03:24 PM
Help! Buddy box hitec aurora 9 as master with opentx taranis as slave kuroguy Radios 0 Mar 27, 2016 04:09 PM
