Jul 26, 2021, 11:55 AM
JohnCl's Avatar
Feebay has the WL Toys V911S with transmitter and two flight batteries for $50.00. I had Hours on these learning. Fun too!
Jul 28, 2021, 08:59 AM
Is what I'm doing helping?
Steve_'s Avatar
For the money they are hard to beat. Fixed pitch helicopters are loads of fun and when properly set up can make some decent banked turns
and actually look fairly realistic. After adding some LED's my son and myself used to play tag on calm nights. You have to work pretty hard
to break them.
Micros are certainly the cheapest way to learn CP's (not counting simulators).
After almost totaling a full CNC stretched blade 400 I decided to get something smaller, the MCPX V2.
At lunch hour I would race to a deserted section of the factory. Took over 3 weeks to fly smooth figure 8's.
My oldest boy picked it up in a few flights. My excuse was that I'm old and can't see.
[EDIT] Went through probably 7 or more tail assemblies, but it was still cheaper than crashing a bigger (modded) heli even once.
Found old pic of the Blade 400. Someone had it upgraded and then never picked it up, so the LHS sold it to me.
Along with the CF and CNC parts it has a Futaba GY520 gyro and a really good tail servo.
In it's day a hard crash would have been expensive.
Aug 18, 2021, 07:47 PM
The real flight trainer sim is a great value and I bound my DX6e to the computer with the usb dongle. I have the Blade 230s v2 and it flies very similar to the 230s in the sim.
Sep 02, 2021, 08:05 PM
Lookin' up at the centerline
taildragger1589's Avatar
Hi BillM67,
I'm hoping you can answer a question for me...
Learned to hover in 2004 with a helicopter called the honey bee. Never did learn to fly forward. Just hover.
Learned to fly forward on a simulator which inspired me to buy a WL toy v912
Got to where I can do circles pirouettes and recognizable figure eights.
Being 67 and having the onset of cataracts I needed something a little bigger, around a 20 inch rotor span. Was considering both the blade 230 and the OMP discussed on the previous page. Though they're not much bigger.
The only thing holding me back from the blade is that smart battery. I don't want it. Is it difficult to switch over to a normal lipo? Just for the record I have a spectrum dx6e transmitter.
Nick
Sep 03, 2021, 03:59 PM
JohnCl's Avatar
Watch the for sale forums for a good used 230V2. Before the smart stuff. My two fly great and sure have taken a beating!
Sep 03, 2021, 08:00 PM
Appreciate the steer.
I'll do that.
Just in case anybody else is wondering, I've come across several people that just cut off the smart connector and put on a deans or an xt60 connector.
Sep 07, 2021, 08:35 PM
I'll do that.
XT60 is a little big most use XT30 but confirm your point. Change it out to ones needs. Or could make up an adapter or buy one.
Sep 07, 2021, 10:22 PM
I've made up quite a few adapters, trying to get xt60 or jst as the only two for my entire fleet.
I was just afraid there was some kind of circuitry that would prevent me from swapping connectors.
Now that I know, I'm going to go ahead and order one since it seems to be the most forgiving of all the larger helis.
Sep 18, 2021, 07:32 PM
Got a 230s and it's just the size I was looking for.
Unfortunately I've been wrestling with it for four days now and have yet to leave the ground.
First two attempts, it just rolled over on it's side.
3rd try, I could hold it upright with 25 % right cyclic but the tail rotor was firing off random bursts that jerked it around too much to attempt lift off.
I tried rebinding many times with no luck.
Triple checked the set up table in the book (I have a Dx6e) and it's all good.
Used forward programming to calibrate the controller and it just sits there and beeps flashing yellow, green and solid red.
I let it beep and "calibrate" for 30 min. but it just won't click in.
Also tried a factory reset for the controller, with another failed calibrate and it's uncontrollable as before.
Kind of frustrating but I know where the heli learned how to behave.
From their web site.
At the registration screen, I filled out all of the various numbers, address and such then clicked on submit.
Got the response in red type "submission failed please try again later.
Called them on the phone, got a recording telling me they were too busy with calls, please go to web site, then hung up.
Went to the web site and filled out all of the data (again) along with the problem I was having.
Clicked on Submit....
You guessed it. Failed submission, try again later.
So I sent them an email describing the problem.
They promised to get back to me in 48 hrs, skipping Sunday, I figure they'll get to me by tues night.
We'll see
Sep 21, 2021, 02:15 AM
We'll see
Look in the Micro Heli section under 230S V2/Smart. All your answers are there.
But to calibrate the FC you need to unplug all 3 wires for both main and tail motors. HH neglected to put this step in the manual.
Good luck
Sep 21, 2021, 10:48 AM
Good luck
Thanks for the steer.
The Blade now calibrates in 20 seconds.
But now the tail rotor doesn't answer the stick or the gyro.
but the blade makes nice stable lift offs while spinning around.
Will look at the blade thread.
Nick
Discussion Heli comeback? beginner scale heli caribbean_fox Electric Heli Talk 11 Apr 21, 2020 10:21 PM
Discussion What 4ch Heli should a beginner buy? ilickpie Micro Helis 22 May 28, 2008 09:06 PM
Discussion Whats the smallest heli for a beginner? DigitalAce7 Mini Helis 8 Sep 29, 2006 05:05 PM
What micro heli for a beginner? guillaume83 Micro Helis 4 Nov 11, 2003 07:58 AM
Beginner delima's about what heli.... Heli Slime Electric Heli Talk 6 May 11, 2003 12:09 AM
