This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Jan 23, 2021, 06:24 PM
old4570's Avatar
UMX TT Signal loss
UMX TT signal loss (5 min 22 sec)
Re routing the antenna helped some ! But not enough !
So I have punched more holes in the TT and this time routed the antenna out the bottom of the fuse , maybe 1mm .
Range checking was good , at least double what I got before .
Butt ! @nd its a huge Bee Hive ! This antenna definitely seem to have a dead zone .. And that appears to be when it is directly pointed at the Tx .
Thats why I have it sticking vertically down .. Which does not eliminate the possibility of the dead zone ..
Last time , the prop did come lose ! Hence the funny sounding motor run .
That small cheap nasty self tapping screw seems to have stripped out the prop shaft .
So I had to replace it with a hex head screw . More butchery of the foam spinner , required .
Do I have to mod the antenna ?
Discussion New DX6 & SAFE RX Range Issue / Signal Loss RadioGaga Electric Plane Talk 4 Mar 22, 2016 12:44 PM
Discussion V-tail mixer - loss of signal state? KiwiDavid Flying Wings 2 Nov 02, 2015 11:17 PM
Help! TS 58200 Xmitter/RC 5808 signal loss Mustang MadMan FPV Equipment 0 Oct 18, 2015 11:45 PM
Discussion How to wire loss signal aircraft finder for DJI phantom bdinh2hh Multirotor Drone Electronics 0 Sep 30, 2015 01:27 PM
