Jan 23, 2021, 12:29 PM
Looking for info
Got this plane before it ended up in a trash can.
Would like to find the same model and make to put the motor and retracts in it after cleaning them up.
It has a Rossi 60 and has a 65Ē wing span
Jan 23, 2021, 01:09 PM
Looks like you got yourself a Curare there.
carl
Jan 23, 2021, 01:30 PM
Brighto?
Mike Denest's Avatar
The guys here classic-pattern-flying can tell you all about it. Looks to be a good restoration project. I'm hanging around the wrong trashcans.
Jan 24, 2021, 03:50 PM
AMA 537620
ChillPhatCat's Avatar
Seriously... where can I find someone tossing a piped Rossi in the trash.
Jan 24, 2021, 04:34 PM
Southern California lol
Really I donít think the airframe can be saved but I would like to find a replacement for it
Jan 24, 2021, 08:59 PM
coriolan's Avatar
If you want to build one:
https://outerzone.co.uk/plan_details.asp?ID=5527
https://outerzone.co.uk/download_fil..._60_oz5527.pdf
https://outerzone.co.uk/download_fil...rticle_MAN.pdf
https://outerzone.co.uk/download_fil...ticle_RCME.pdf
https://outerzone.co.uk/download_fil...7_parts_V2.pdf
Jan 24, 2021, 10:48 PM
AMA 46133
SeismicCWave's Avatar
If you cannot save the airframe then all you get really is the engine. If some one toss it in the trash can you may want to take the engine apart to check if it is worth salvaging. Pretty hard to find piston and sleeve for the Rossi 61. Probably easier to find a whole engine.
There must be a reason why the plane is in the trash......
Jan 25, 2021, 02:31 PM
Send lawyers, guns and money
ahrma_581's Avatar
Left it out in the sun too long and the elevator melted?
Jan 25, 2021, 03:02 PM
It looks like there hasnít been a drop of fuel in it.
Pulled the motor and the air retracts.
Jan 25, 2021, 04:55 PM
AMA 46133
No sure what that meant. If there is not a drop of fuel in it that just meant it has not been run for a long time and what ever is in it dried up or evaporated. The engine looked used. I am sure it had fuel in it before.
Jan 25, 2021, 07:45 PM
JimboPilotFL's Avatar
Really I don’t think the airframe can be saved but I would like to find a replacement for it
There are a lot of short kits and foam wings here.
http://www.eurekaaircraft.com/all_kits.htm
Curare http://www.eurekaaircraft.com/plan_kits/curare.htm
Jan 26, 2021, 11:01 AM
AMA 537620
I'm sure if you don't take it literally, he could mean that there is no carbon build-up or at least the engine looks very clean. It does look like a pretty decent engine from the pics. If it rotates smoothly and has compression... then it's probably good to go.
Jan 26, 2021, 01:39 PM
AMA 46133
There is definitely a fine layer of rusts on the exterior steel parts. If the engine has no fluid on the inside I am almost certain the crank shaft and bearings will also have rusts. So a full disassembly and parts replacements will be necessary as the minimum.
What I didn't see from the picture is evidence of castor oil deposit. Maybe that's what the OP meant by no fuel.
Jan 26, 2021, 02:19 PM
Unless there is more damage than I am seeing in the photos, that airframe looks repairable to me.
Discussion Looking for some info asap emtiv09 USA - District IV 1 May 18, 2016 09:55 AM
Help! Looking for info: IJN WWII Life Rafts HOLDEN8702 Scale Boats 1 Apr 17, 2016 08:33 AM
Discussion can anyone help with these rc10's looking for info kcolraw Off-road Cars 42 Nov 24, 2015 01:52 PM
Discussion Looking for info on dethermalizer timers fulldec Free Flight 9 Sep 30, 2015 12:05 AM
Discussion Looking for Info/Pic: Disco Boy DLG of Paul Siegel Thermaln2 Hand Launch 8 Sep 18, 2015 12:03 PM
