Thread Tools |
This thread is privately moderated by old4570, who may elect to delete unwanted replies. |
More Turbo Timber - Rudder Mix
I mixed in some rudder in stability mode to tighten the turns .. From memory the mix is for 20% rudder added to the ailerons , and it really helps in tightening the turns . I was thinking that the TT would be a nice tight space flier but in stability mode it's a little lazy with just bank and yank ! So mixing in a little rudder really helps kick the tail over . And with the TT having such excellent slow speed handling , kicking the tail does not hurt . After a little over 4 minutes flight time , I had 53% battery when I came home . The vertical performance is not brilliant and then again it's not terrible , maybe a little ho hum ! I will have to see about a 2 blade replacement prop . Signal Warnings - I lowered the warning point / signal strength .. No joy there ! So today I came home and punched some holes in the side of the fuse and pulled the antenna thru ! Then tapped it to the outside of the fuse , just a bit of tail sticking out . ( pictured ) Tripled my range check . ![]() ![]() |
Thread Tools | |
Similar Threads | |||||
Help! | New Turbo Timber 1.5 rudder issue | Morray | Electric Plane Talk | 4 | Dec 20, 2020 05:09 PM |
Discussion | E Flite Turbo Timber mix down elev with high throttle. | Scottrog | Electric Plane Talk | 26 | Apr 06, 2020 07:02 AM |
Discussion | Water rudder mixing to air rudder | sunjazz | Radios | 23 | Nov 12, 2019 10:16 PM |
Discussion | Timber X or Turbo Timber | ttaylor63 | Electric Plane Talk | 10 | Nov 08, 2019 03:10 PM |
Discussion | Mixing rudder with ailerons help and more. | roundthebend | Sailplane Talk | 4 | Jun 10, 2008 02:12 AM |
