Jan 22, 2021, 07:42 AM
rcpilot_hun's Avatar
Help!
how to configure well SoftSerial of F4 flight controller?
Hi, Guys!
I use a JHEMCU F4 flight controller, which is similar than BF Omnibus F4SD flight controller. I used Serial RX (UART1), I2C MAG (UART3) and GPS (UART6).
I'd lke to connect onto FC an external Bluetooth module, but there is no free UART port... I read in Forums, that there is possibility to configure MOTOR 5 and MOTOR 6 outputs as TX-RX of a SoftSerial port.
I did following steps:
Betaflight: Configuration/SoftSerial enabled
reboot
CLI
resource MOTOR 5 none
resource MOTOR 6 none
resource SONAR_TRIGGER none
resource SONAR_ECHO none
resource SERIAL_TX 11 A01
resource SERIAL_RX 12 A08
feature GPS
save
I checked inside CLI resource and feature, I attached snapshots: there are alive SERIAL 12 RX and SERIAL 11 TX. I soldered wires to S5/S6/+5V/GND ports, I disassembled GPS from UART6 (where it was wirking), and I connecred to SoftSerial (1 or 2???).
The GPS is working in new port (
gps is working (0 min 15 sec)
), but the BF Configurator can't identify it...
Have You got any idea, what does block working of SoftSerial port?
Thks: rcph
Jan 22, 2021, 09:45 AM
SOLVED !!!! Hooray! I saw video of KeremerFPV, I noticed, He used Serial 11 TX and 11 RX...
I used 11 RX and 12 (!!!) TX! OOoh.
This is the final solution:
CLI
resource SONAR_TRIGGER 1 none
resource SONAR_ECHO 1 none
resource SERIAL_RX 11 A08
feature GPS
save
New Product Racerstar MELO F4 Bluetooth Flight Controller AIO OSD BEC Support APP Configuration alex_nikiforov Banggood.com 0 Jul 10, 2019 08:45 AM
Discussion how to read flight controller data without configurator johthu Multirotor Drone Electronics 7 May 20, 2018 10:16 AM
Discussion How to get telemetry in Taranis with Fortini F4 flight controller Viceroy86 FPV Talk 1 Sep 24, 2017 05:03 PM
Discussion NEW F4 Flight Controller - how to flash it surferguy Multirotor Drone Talk 0 Sep 30, 2016 10:42 PM
