I bought a roll of aluminum tape from the auto parts store. Besides being handy for simulating hatches, it's great for making engine gaskets. Clean the surface, lay on a piece of tape, rub it in real good, then cut away the outside and inside; all done.
carl |
Here are the tape rolls. Measure 3.875 wide and the tape is .003 thick when the paper is pulled from the back. I took a piece of balsa and the tape sticks securely to it. Let me know if you need more information
Joe |
Too heavy, not very nice finish showing all the joints. You'll better off using any silver foil applied with the size, or even better and lighter silver gild it using the size.
On my particular application I want the joints to show. I am duplicating all the 100's of panels by cutting out small pieces for each one and slightly overlapping each one onto the other to create panel lines. After that using a tool to create the individual rivets. The tape used to do this is very thin like .003" or less. Very equal to monokote in weight when done.
Aluminum Tape
Aluminum tape with pressure sensitive adhesive is available from HVAC distributors. It's used for sealing joints in duct systems.
Got mine at Harbor Freight.
Any home improvement store will carry it. Home Depot definitely, as I've bought it there. Great for sealing the exhaust duct on my laser cutter. But sold for sealing joints on HVAC ductwork. Usually available in a few different widths.
Thread Tools | |
Similar Threads | |||||
Discussion | Flite Metal Status | bguffer | Painting and Finishing Tips | 2 | Jan 12, 2020 09:24 AM |
Discussion | Servo Horns for a E-Flite 9g metal gear | J C Harrell | Electric Plane Talk | 0 | Jun 14, 2017 09:46 PM |
Link | Flite-Metal Temporary Site | FliteMetal | Product Announcements | 0 | Nov 30, 2016 11:42 AM |
Discussion | Top Flite P-47 Bare Metal Finish | jseese | Painting and Finishing Tips | 3 | Apr 17, 2016 10:34 PM |
Question | E-flite 15-25 retract metal nose gear trunnion | wyldkrd | Electric Ducted Fan Jet Talk | 5 | Mar 08, 2016 08:39 AM |
