Engine choices for Excelleron 90 - RC Groups
View Poll Results: Engine choices for Excelleron 90?
OS MAX 0 0%
SAITO 1 100.00%
YS 0 0%
THUNDER TIGER 0 0%
SUPERTIGRE 0 0%
Voters: 1. You may not vote on this poll
Jun 10, 2005, 12:56 AM
Proud crasher since 1975!
Arthur_GA's Avatar
Poll
I'm about to receive my Excelleron 90 and still have to choose a powerplant.
What engine (brand, 2 or 4 stroke) do yuo use or would use on this plane?
Jun 22, 2005, 04:00 PM
Why's the rum always gone?
longhair's Avatar
FWIW-I have a YS 120 in mine...overpowered but it won't need another engine as I progress. I think an OS 1.20 would be a nice match.
Dec 27, 2005, 07:17 AM
perttime's Avatar
I have been looking at the MVVS 2 stroke engines. Nobody seems to have a bad word about them and the cost is pretty reasonable. I like the possibility to set them up as rear exhaust engines too.
http://www.mvvs.com
http://mvvs.nl/
http://www.mvvs.cz
Jan 06, 2006, 06:50 AM
mikedsilva
excelleron 90 engine choice
i am thinking of using an OS1.20 with a pump... i hear it is a heavy motor (33 ounces or so) so would i have to relocated servos to the tail of the plane to make up for the extra nose weight? some ARFs are tail heavy to start with... what is the general consensus of this powerplant to be used in E 90?
mikedsilva@optushome.com.au
Jan 06, 2006, 10:08 AM
look mamma, I can Fly!!!
Guille's Avatar
MVVS could be a nice answer... In case you choose the .90 I reccomend you put a tuned pipe on it. I had a 77 and worked very well (no complains) spining a 13x8 or 14x6 at alsmos 11500 rpm. Now I've a GMS 120 which weigths 750 gr w/o muffler spining a 16x8 on a panther (check the other thread).
Also seems that any 4St 120 could be a good answer too.
Cheers!!
Jan 06, 2006, 08:02 PM
Guille's Avatar
Did you think on any electric engine (any hacker)? I know that thery are expensive but...
Jan 30, 2006, 05:09 AM
scones007's Avatar
I have YS DZ 1.40 in it unlimited verticle at 1/2 throttle.I placed my battery pack just behind the wing.Had to add 2 oz. lead to' the tail.A bit heavy for super slow landings,but overall flies great.Its a bit over powered Talk about the need of throttle management LOL.A 1.20 would be better suited for it.I also put a .91 2c in it moved battery all the way forward removed the lead.Flies nice goes verticle but doesn
t speck out like the it does w/1.40.but lands so slow & gently .
Jul 06, 2016, 02:30 AM
Excelleron 90 and DLE 20cc?
Has anyone had any experience flying the excelleron 90 with a DLE-20Cc gas engine?
Would anyone recommend this combination?
Aug 25, 2016, 11:28 AM
Wow, not often you see a thread revived after ten years of no posts, lol. I think the DLE20 might be a bit heavy but cannot say for sure. Did not have the 90 size Excelleron...I had the 50 size with a OS70 four stroke in it that was perfect. I miss that plane very much. It expired too young due to elevator servo failure. Good luck no matter what you put in your bigger version...it is just a fine flying airframe.
Sep 05, 2016, 03:52 PM
PhoenixFlyer
PhoenixFlyer's Avatar
Stump Puller. Nothing comes close. IMHO
Sep 06, 2016, 11:16 PM
Faster is Better
Slopemaster's Avatar
YS 61 Long Stroke was my engine of choice. Of course that was 25 years ago.
Latest blog entry: LEG Fat Albert Take 2
Feb 12, 2017, 10:26 PM
How about an ASP .91?
Feb 13, 2017, 12:21 PM
Can someone please guide me in which Electric Motor could me most suitable for the Excelleron 90? I know nothing about electric motors, I come from a long history of Nitro flying.
Or do you guys suggest still go for nitro?
Feb 14, 2017, 08:58 PM
Closed Account
Any of the 110 size outrunners and 6 cell setups should work well.
Feb 24, 2017, 02:34 PM
Thanks everybody for the replies and advice in choosing the powerplant for the Excelleron 90!
If you had to choose between:
- ASP .91 Red Head with Stock muffler
- Electric motor
- DLE 20 gas engine
- Rossi .91 Rear Exhaust with tuned pipe
What would you choose?
Discussion Engine Selection for a Aeroworks .90 - 1.20 vahn Engines 2 Jun 30, 2007 04:24 AM
Question Engine for Funtana 90? 2S or 4S?? FlattyFlier Engines 19 Dec 20, 2006 09:30 AM
engine for 60/90 size Edge 540 iloverc Engines 2 Jun 14, 2003 10:39 PM
narrowed down choices for my first HLG! Need help selecting. MichaelConnally Hand Launch 19 Sep 08, 2002 04:40 PM
Lite Stick Engine Choices for Newbie Gman Parkflyers 2 Jun 04, 2001 02:36 AM
