Thread Tools |
This thread is privately moderated by old4570, who may elect to delete unwanted replies. |
XK A160 with more down thrust
I may have previously mentioned ! That I removed the motor+ mount and rotated it 180deg for more down thrust ! Because - When I applied power , the nose would lift and the A160 would climb seriously hard over 50% throttle .. Up to 50% was ok but once I wanted more ( like 100% ) the A160 just lifted it's nose . Rotating the motor mount seems to have seriously improved things . I did change my elevator setting causing the A160 to climb . I did put in some down trim , but looks like I have to go back where I was .. But never the less a serious improvement . Having solved one issue , looks like CG might be next . It does hunt up and down a bit and drag it's beehive in turns ( signs of a rearward CG ) ![]() Playing with the CG |
