Cheers |
What is your control radio frequency? 2.4GHz? |
The y harnesses for the power are starting to come together. That 60 watt iron makes a difference. It got hot so quick I melted my deans. Lesson learned..be ready with the wire!
Regards, Eric. |
Cheers |
I intend to use 5G8 vtx and vrx. Did you get any chance to look at the wire diameter again? Cheers |
The big advantage is that it fits the spar channel with no need of modification. And that it is less prone to breaking because of its flexibility. |
Thanx a lot for the info. I've some wires in stock which are silicon sleeve and are very flexible. The dia is 1mm so I make the area as 1.5 mm2. I've been thinking of replacing the existing wires with the above material. Unfortunately, I've lost the specification so gathering info before replacing the existing wires. Cheers |
Zoltan's customer service is amazing! |
Thread Tools | |
Similar Threads | |||||
The Mpx Micro-Jet has arrived! (Part II) | flieslikeabeagle | Foamies (Kits) | 57 | May 06, 2007 10:32 PM | |
Discussion | MPX Twinstar II in Australia | maxy333 | Foamies (Kits) | 1 | Feb 25, 2006 04:25 PM |
Yippee! | MPX Twinstar II maidened today!! | Chetto1965 | Electric Plane Talk | 10 | Feb 08, 2006 02:09 AM |
Discussion | MPX Twinstar II configuration? | Chetto1965 | Electric Plane Talk | 9 | Jan 05, 2006 02:20 AM |
The Mpx Micro-Jet has arrived! | Jurgen Heilig | Foamies (Kits) | 655 | Jun 05, 2005 03:46 AM |
