Laser Goo
Really coolant system Goo.
I was doing an engraving the other day and noticed a streamer of Goo in my laser tube. It was hung up on one of the dimples that supports the inner laser tube. At first I just figured I leave it as a flow indicator ( joking ). I drained part of my cooling system and added some Vinegar to hopefully kill anything that is actively growing. After letting that run a bit, I still had my streamers in the tube, so I did a few cycles or back flushing, forward, back.... Finally got all the streamers loose and cleaned them out of my filter.. I'll let the Vinegar mix run for several hours then do a few flushes of fresh distilled water. I bought some aquarium anti fungal/algaecide to add when I do the final refill. I expect part of the reason I have a growth issue is that my laser sits for long periods of time. Has anyone else had this issue? Do you add anything to your coolant? I've googled this and opinions seem to vary quiet a bit. Joel |
If it's a closed-loop cooling system, fill it with Mineral Oil instead of water. It won't grow anything. And if it leaks inside your machine, it won't short circuit anything. Mineral Oil is what's in my Glowforge and all the CPU coolers I have in my workstations.
it is a bit more viscous, but not a lot. They call them "water cooling blocks" in the PC world, but they're all filled with mineral oil, not water. Because: leaks.
I use Tetra aquarium water treatment and it has worked fine for me.
SteveT. |
Latest blog entry: My shop....
Thread Tools | |
Similar Threads | |||||
Discussion | Xylene instead of Toluene for thinning Goo? | Brett_N | 3D Foamies | 2 | Nov 17, 2018 08:24 PM |
Question | Shoe goo or Expoy | DiscoMike | Dock Talk | 19 | Aug 19, 2018 04:30 PM |
Question | Blue Goo Leaking Out of Balance Connector | vonJaerschky | Batteries and Chargers | 15 | May 27, 2016 11:37 AM |
Question | UHU vs. GOO & GOO II | weed | Beginner Training Area (Aircraft-Electric) | 10 | Sep 06, 2008 06:49 AM |
