Maximum Charge Rate: 20A |
Maximum Continuous Discharge Rate: 1.5A |
Number of Cells: 1 - 6S LiPo, LiIon, LiFe, 1-16 cell NiMH, NiCd, 1-12 cell Pb |
Input Voltage: 100 - 240V AC |
Output: 2 x 200W, or 380W on one channel |
Output Connector: IC3 and IC5 selectable |
Normal/Standard Charge Rate: 0.1 - 20.0A |
Available From: Horizon Hobby |
Price: $249.99 |
The latest in Smart lipo battery charging is available now from Horizon Hobby. Electrics have come a long way over the last couple of years. The performance of electric aircraft and surface vehicles has grown and with that growth comes greater demands on the lipo batteries and the chargers used with them. Horizon is once again at the forefront of development in this field with their new S2200 G2 Smart charger and their new G2 Smart Lipo batteries. In this review I will go over some of the features of these new products and how they perform.
Horizon sent me several of the new G2 Smart Lipo batteries for testing along with the S2200 Smart Charger. The first thing that I noticed was the lack of any balance lead on the batteries. In the photo above I show the comparison of a G1 Smart Lipo with balance lead and a G2 Smart Lipo without balance lead. The G1 looks more like the batteries that we have become accustomed to using and charging. Both G1 and G2 batteries use the IC3 or IC5 smart connector that incorporates a thinner data wire to transmit and receive information between the Smart Battery and the Smart Charger.
Let's first go over how the new S2200 G2 Smart Charger is laid out. It is a fairly compact charger measuring only a little under 6 inches in width and depth and a little over 4 inches tall. Its compact form doesn't take up a lot of space on your workbench and it's easy to transport to the flying field (if there is AC power at the field). On the top of the charger is a bright 2.8" color screen that displays all the charging information. Below that are the navigation buttons to move through the various menus. I found the navigation to be quite intuitive and became comfortable quickly. Moving to the front of the charger there are 2 each of the IC3 and IC5 output ports built in. The appropriate port can be accessed by sliding the cover to expose it. When charging smart batteries no additional adapters are required. The left side of the charger has a full size USB output for charging other devices. There is also a micro USB input port for updating software as updates become available. The back of the charger has the AC power input. The AC cable is detachable which I like as it makes the charger much less bulky to transport. There is also an ON/OFF switch so unplugging is not required to power down the charger. There is a large cooling fan located in the rear as well.
To charge a G2 battery all you do is plug it into the integrated IC3 or IC5 charge port. That's it, that's all you need to do. The smart charger recognizes the smart lipo and gets its charge parameters from the batteries internal microchip. The smart charger auto-detects everything needed, cell count, charge rate, battery condition. This is really quite remarkable. Up till now, whenever you charged a lipo battery you needed to plug it in, plug in the balance connector, check the cell count, check the charge rate and set it if necessary and then press a start button. The S2200 boils all that down to just having to plug the battery into the charger. It detects all the specific parameters for that battery and safely begins to charge and balance the pack. If you are charging a G1 Smart Lipo there is one additional step required, you must plug in the balance connector to initiate the charge. When you plug in a G1 Smart Lipo the charger prompts you to do this.
Can the S2200 charge my conventional non-smart lipo packs? Yes it can, although not by simply plugging the battery into the charger. The S2200's IC3 and IC5 output charge ports are backward compatible with EC3 and EC5 connectors. The charge process for non-smart packs is fairly similar to what you are probably already familiar with. The pack and balance connector must be plugged in and then you choose the charge parameters. The cell count is auto-detected from the balance connection. Charge current must be selected and the start button pushed.
Two batteries can be charged at the same time. Each battery's progress can be monitored on the main screen, switching between channels via the channel buttons.
When I go to the flying field I usually bring several models and a tub of batteries. I have developed the habit of checking the pack voltage prior to installing a pack into my airplane. There is nothing worse than thinking you have a full charge when in fact you don't. Up until now I have used a cell checker that measures the individual cell voltages when the balance connector of the pack is plugged in. Well, now with the new G2 packs that do not have a balance connector, something different is needed to check the pack status. Enter the XBC100 Smart battery checker and servo tester. With this the individual cell voltages can be checked just by plugging the IC3 plug into the checker. If your Smart Lipo pack uses an IC5 connector you will have to use an IC5 to IC3 adapter.
While I haven't had this charger for a long time, I am very pleased with the performance and ease of use. The new G2 Smart LiPo batteries can be charged and balanced in the simplest way possible. I like the ability to monitor and adjust battery parameters and keep track of battery health. I look forward to exploring all the benefits of Smart batteries in some of my aircraft. If you are in the market for a powerful, intuitive and flexible charger, you should look into picking the S2200 G2 Smart Charger.
RCGroups.com Review Policies
Our intent is to provide fair and unbiased reviews so that consumers can make informed decisions regarding new products. Some things you should know about our review process:
It is always our intent to provide a place for honest and open commentary, and to put the needs of our visitors first. If you feel that something we've published is inaccurate, please let us know using the contact form.
I set the auto storage to 48 hours on one my smart lipos; 72 hours later and the lipo is still at full, so I discharged it manually to storage charge. I tested my other smart lipos to 24 hours and 48 hours they're still at full charge. What am I doing wrong? Shouldn't they discharge automatically to the settings I selected?
My question is, What can this charger really do? Says "UP TO" 200 W per side.
Take two Spektrum 6S 5000 MAH batteries should be able to charge simultaneously at 7 + amps per side. I have heard the real world charge rate in amps for this charger is 4 amps for a 6S pack, which is 100 watts per channel. That is a long way from "UP TO" 200watts per side. Seems the words "UP TO" are marketing attention grabbers, for something that in reality is nothing better than a normal AC charger. With the exception of convenience, which is worth some coin. Too bad I was ready to sell my DC power supply and 308Duo, and get one of these, for convenience of only having to lug a single device to do my charging at the field. Can the tester or HH provide counter testimony in the form of a video, showing two 6S packs charging simultaneously at something close to 200 watts per side? |
Looking forward to real world reviews showing different charging combinations with different size lipo packs. |
Thread Tools | |
Similar Threads | |||||
New Product | iSDT D2 200W 20A AC Dual Channel Output Smart Battery Balance Charger | D Gains | Batteries and Chargers | 53 | Dec 07, 2020 01:12 PM |
Mini-Review | ISDT D2 200W/20A AC Dual Channel Smart Charger Review | czajunia | Batteries and Chargers | 90 | Nov 13, 2020 07:34 PM |
New Product | ISDT 608AC AC 60W DC 200W 8A BattGo Smart Battery Charger Discharger with Detachable | alex_nikiforov | Banggood.com | 0 | Sep 03, 2019 10:50 PM |
