Jun 08, 2005, 01:36 AM
Make one 3s2p from two 3s1p
Hello.
I have a Quest Storm with the biggest Nippy motor and I do not have the punch I think the motor can deliver. Now I use PQ1800 3s1p and I do think that they are limiting the current. I wonder if I can just connect two packs paralell without risking anything? The extra wheight will be ok with the plane. Of course I will check that it's two fully charged packs. Is there anything more I shall do/think of?
Regards Mats
Jun 08, 2005, 01:48 AM
Naturally altered
As long as you airplane can carry it, there's no problem with using two packs in parrallel. You can either build yourself a Y harness to connect both, or more simply attach two battery connectors to your ESC. You'll have to charge them one at a time though. I think that's better with lipos although some will argue parrallel charging works too.
I have a bunch of 3s1p 1250 for small parkfliers, and i have opted not to buy larger packs for larger electrics planes I fly, but put 2 (or 3 in some instances) in parrallel. Easier on the budget than maintaining different packs for different size planes, i am getting max usage from my lipos not leaving them on the shelf to die on their own from old age and lack of usage.
Removing one Cell from 3S1P Kokam 1500 bgijsber Batteries and Chargers 3 Jun 13, 2005 12:07 PM
Can Etec 3S2P packs be split in two 3S1P without aluminum re-soldering Protocooler Batteries and Chargers 3 Jun 24, 2004 05:10 PM
3s2p from two 3s1p? Doc Data Batteries and Chargers 3 Dec 26, 2003 03:59 PM
Is a 3S2P three 1S2P in series or two 3S1P in parallel? dw1122 Batteries and Chargers 2 Nov 27, 2003 09:45 AM
2S3P, 3S2P, Three 2S1P, or two 3S1P packs from 6 lipo cells erashby Batteries and Chargers 3 Aug 15, 2003 07:05 PM
