Question
Carbon tow spar cap sizing.
G'day,
Dunno if this is the right place to ask for help ... but here I am, cap in hand. I'm wanting to calculate the cross-section of the spar caps for a project I'm working on. In the past, I'd have just thought of a number and doubled it ... extra weight be damned. ![]() This time I'd like to use a lay mans method that's somewhere between an over-engineered guess and a collection of lines with jumbled greek characters and numerals that are beyond my comprehension and pay grade. If you're aware of simple calculation for carbon tows that considers bending load and spar depth etc, I love to see it. I've found THIS on the Charles River site. So far I have ... "Take 1/4 of the span in inches and multiply it by half the breaking strength of the tow line in pounds" 66" x 100lb = 6600 in-lbs . ("This is the maximum bending moment at the center of the wing in inch-pounds") "Divide the maximum bending moment by the (top to bottom) spar depth in inches." 6600 lbs/1.25" = 5280 lbs ("This is the force at the center of the wing required of the the spar caps, in pounds.") It is then suggested to "Find the strength of the spar cap material in pounds per square inch". What the ... ??? Modulus, tensile, compression ...? The tow I have is normal/standard modulus (not HM) Can you help with this number ... or do you have a better method? I'm all ears. TIA David. |
See Mark Drela's document describing how to calculate spar cap sizing.
Thanks Wazmo,
So, plugging Dr Drela's value, "cap modulus : E = 2.0x10^7 psi (for common T-300 carbon fiber)" into the next part of the calculation, "Divide the force in the spar caps by the strength of the spar caps to get the required cross section of the spar caps." I get ... 5280/2.0x10^7 = 0.000264 What area is that, square inches, square feet??? ![]() Square feet makes more sense because it converts to ~25mm^2 ... or 25mm x1mm. Add in a fudge factor of 1.5 would be 25mm x 1.5mm. I'm beginning to feel like I should combine old and new methods by doubling the value that I calculate ![]() Aged, confused and drowning in uncertainty. D. |
You may like this spreadsheet. It has been around quite some time, I think I was turned on to it from a thread in the past. If you don't use it for primary calculations it might at least be a sanity check.
http://www.acrodesigns.com/excel/SparStrength.xls |
5280/140000 = 0.0377in^2 ... which coincidentally converts to ~25mm^2. ![]() Who'd have thunk it? ![]() |
Have you used this yourself? From the Spreadsheet (thanks again) I have the following numbers ... but I don't know what to do with them. ![]() 3300 in-lbs = Moment @ Centerline. 12600 psi = Maximum Bending Stress @ Centerline. For this, I used a conservative 6G load number. Yes, it's for a scale model of an Open Class glider and I agree if you're thinking that 6G is extreme. But have you seen how quickly things can go wrong on the tow? ![]() This is for the I beam spar where web width "b" equals the width of the spar cap "b". (** Lots of bonding area). Where to from here? D. |
Good subject!
Dave,
Thanks for putting up this thread at this time. I currently have such a decision right in front of me as you/we/I write. However, I have a small fact to remind you of: You and I and most of the Western world are working in metric units of measurement now; surely you must have already noticed, right? The resort to "Olde Worlde" imperial (former British) units is regressive and on a person level, phases me out completely. Who are you trying to appease? Don't bother answering that; we already know!...................... ![]() From this site here: https://www.worldatlas.com/articles/...al-system.html Who Uses The Imperial System Today? Now, this might surprise you, but there are only 3 countries in the world that are still officially using the imperial system: The United States of America, Myanmar, and Liberia. Which is a very short list indeed! I rest my case.................. ![]() Respectfully yours etc. Jim. |
Graduated high school in 1976 with the knowledge of conversion from Imperial to Metric, it was coming they said. So is Jesus.
I have patience . . . ![]() For those that didn't learn it in high school . . . ;>) https://www.calculator.net/conversion-calculator.html Joe Balsa Breaks Better Woodys Forever |
The germans mostly use Christian Barons spreadsheet. His website is not up anymore, but I have attached the file. Change extension from .txt, to .xls.
Lars |
I haven’t seen Christian Baron’s name for a very long time. I’ll crunch some numbers and see how it compares to the fumbled attempts so far. D. |
What do others use for that value? ![]() Tom f. |
Can anyone get that text file of Christians to open?
I cannot get it to open in Linux Mint 19.3 Jim. |
Thread Tools | |
Similar Threads | |||||
Discussion | PVA for carbon spar cap in kraft paper-foam wing? | DKNguyen | Composites Fabrication | 0 | Feb 16, 2017 01:13 PM |
Question | Rib Caps and Torsional rigidity & Carbon tow on spars for strength??? | Pauliwog | Thermal | 46 | Jan 01, 2016 12:22 AM |
Discussion | Spar caps molded from 50K tow | Anker | Sailplane Talk | 10 | Feb 19, 2012 10:12 AM |
Discussion | Carbon tow vs Unidirectional matting for spar caps | jjmouris | Composites Fabrication | 7 | Aug 15, 2010 12:32 PM |
Question | Fabricating spar caps from 12K carbon tow | JayGarcia | Composites Fabrication | 14 | Mar 15, 2008 09:24 PM |
