Thread Tools |
This thread is privately moderated by old4570, who may elect to delete unwanted replies. |
UMX TT Lives
It lives ... Battery will be a 300mAh from OMPHobby T720 .. Flying weight looks to be around 122 grams Battery will make CG Ailerons have - 50% / 75% / 100% rates Elevator / Rudder have 100% Expo is 40% for now . This may need to change . Motor / Prop pulls 6 amps ... ( Will need to explore propeller options ) BIND ( To Taranis Qx7 with multi protocol module ) Tx = DSMx-22 I turned on the Tx and got it ready to bind . Turned on the UMX TT Once the TT had beeped and thrown the control surfaces around some and STOPED ! I then activated the bind in the Tx .. 5 Seconds or so later the Tx was bound to the TT .. CH5 is for flying modes ( Stability or not ) = You may need to reverse the Ch to get the mode you want for switch position CH6 is for the Flaps - I slowed mine down 0.5 seconds up and down . I did need to reverse my rudder .. And here we are ! TT is back in the box and Tx is set up , battery is charged . Just need for the weather to co operate - Which might be next week ? We are having a bit of a wintery summer so far .. Cool / wet and windy ! I dont mind the cool , I dont mind the wet , but the wind can take a hike ! |
Thread Tools | |
Similar Threads | |||||
Discussion | TT-CopterRedundancy TT-CR V1(connect two FC) | sjak | Multirotor Drone Electronics | 0 | Feb 13, 2016 11:25 AM |
Discussion | Tamiya TT-01, TT-01D, TT-01E, TT-01R??? | hijact | Car Talk | 1 | May 12, 2010 04:47 PM |
