Jan 02, 2021, 11:30 AM
hager's Avatar
Build Log
3DLabPrint Joker Build
I decided to build a 3DLabPrint Joker and Spitfire over the winter months. It has been a fair amount research locating the required components so here is a list of what I will be using for the Joker build. The first print went well using the recommended settings from 3DLabPrint and Simplify3D on my Prusa i3 MK3S printer. Updates to follow as the build progresses.
Components
EMAX GT2215 GT2215/09 1180kv Motor
Turnigy Plush 30A ESC
Turnigy Nano-Tech 3S 65C-130C 1800mah Lipo battery
Turnigy Nano-Tech 200mm Battery Strap
Frsky GRX8 Vario receiver
(2) HTX900 Micro Servo, 9g
(4) Corona DS-239MG Slim Wing Servo, 22g
(2) 15cm servo extensions
(2) 45cm servo extensions
Aeronaut Cam 10"X6" (25.5x15 cm) blades
Aloft Hobbies Turbo Folding Prop Spinner, 36mm
Aloft Hobbies Turbo Folding Prop Spinner Collet, 4mm
MP Jet Plastic Clevises, M2
2mm all threaded rod
K&S Metals 0.039” (1mm) music wire (push rods)
Dubro #511 antenna tubing (0.074" ID 0.134" OD push rod housing)
Carbon fiber tubing - 6mm OD x 4mm ID x 360mm long, 6mm OD x 4mm ID x 640mm long
Miscellaneous hardware as called out in the 3DLabPrint manual
Fillamentum PLA Crystal Clear Iceland Blue, 1.75mm
Fillamentum PLA Crystal Clear Amethyst Purple, 1.75mm
colorFabb PLA/PHA Orange Translucent, 1.75.mm
Hatchbox PLA True Black, 1.75mm filament.
BSI Insta-Cure+ Medium CA
BSI Insta-Set Accelerator
Jan 02, 2021, 07:27 PM
hager's Avatar
Fuselage Parts Weights
I weighed my parts for the fuselage. These were printed using colorFabb PLA/PHA Orange Translucent 1.75mm filament and the default 3DLabPrint processes in Simplify3D. Not bad for the first time printing with this filament.
Part_______Factory / Actual
Fuselage part 1 - 32g / 35.15g
Fuselage part 2 - 42g / 44.90g
Fuselage part 3 - 23g / 25.21g
Fuselage part 4 - 25g / 26.26g
Fuselage part 5 - 17g / 17.31g
Fuselage part 6 - 19g / 20.08g
Total Weight - 158g / 168.91g
Jan 03, 2021, 11:15 AM
hager's Avatar
V-Tail Parts Weights
Small Print job from last night before I change colors. These were separated in the factory file and exported using the original processes.
I weighed my parts for the V-Tail. These were printed using colorFabb PLA/PHA Orange Translucent 1.75mm filament and the default 3DLabPrint processes in Simplify3D.
V-Tail part 1 Left - 11g / 11.86g
V-Tail part 1 Right - 11g / 11.86g
V-Tail part 2 Left - 8g / 7.86g
V-Tail part 2 Right - 8g / 7.83g
Total Weight - 38g / 39.41g
Jan 03, 2021, 02:01 PM
hager's Avatar
Servo Holder Parts Weights
I weighed my parts for the servo holder. These were printed using colorFabb PLA/PHA Orange Translucent 1.75mm filament and the default 3DLabPrint processes in Simplify3D.
Servo Holder - 8g / 8.37g
Central Wing Clip - 2g / 2.17g
Total Weight - 10g / 10.54g
Jan 04, 2021, 10:27 AM
hager's Avatar
Wing Center Section Parts Weights
I weighed my parts for the Wing Center. These were printed using Fillamentum PLA Crystal Clear Iceland Blue, 1.75mm filament and the default 3DLabPrint processes in Simplify3D. Not bad for the first time printing with this filament.
Wing Part 1 Right - 79g / 84.91g
Wing Part 1 Left - 79g / 84.86g
Total Weight - 158g / 169.77g
Jan 04, 2021, 01:20 PM
hager's Avatar
Servo Cover Parts Weights
I weighed my parts for the Servo Covers. These were printed using Fillamentum PLA Crystal Clear Iceland Blue, 1.75mm filament and the default 3DLabPrint processes in Simplify3D. Two separate print jobs a 54mins each.
Servo Cover - 5.5g / 7.11g
Total Weight - 11g / 14.22g
Jan 05, 2021, 11:56 AM
hager's Avatar
Wing Outer Section Parts Weights
I weighed my parts for the Wing Outer Sections. These were printed using Fillamentum PLA Crystal Clear Iceland Blue, 1.75mm filament and the default 3DLabPrint processes in Simplify3D.
Wing Part 2 Right - 41g / 44.55g
Wing Part 2 Left - 41g / 44.59g
Wing Part 3 Right - 35g / 38.95g
Wing Part 3 Left - 35g / 38.90g
Total Weight - 152g / 166.99g
Jan 06, 2021, 03:28 PM
hager's Avatar
Wing Tips Parts Weights
I weighed my parts for the Wing Tips. These were printed using Fillamentum PLA Crystal Clear Iceland Blue, 1.75mm filament and the default 3DLabPrint processes in Simplify3D.
Wing Part 4 Right - 28g / 30.13g
Wing Part 4 Left - 28g / 30.14g
Wing Part 5 Right - 22g / 24.43g
Wing Part 5 Left - 22g / 24.44g
Total Weight - 100g / 109.14g
Jan 06, 2021, 09:07 PM
hager's Avatar
Flaps Parts Weights
I weighed my flaps for the wings. These were printed using Fillamentum PLA Crystal Clear Amethyst Purple, 1.75mm filament and the default 3DLabPrint processes in Simplify3D.
Flap Part 1 Right - 5g / 5.87g
Flap Part 1 Left - 5g / 5.91g
Flap Part 2 Right - 7g / 7.62g
Flap Part 2 Left - 7g / 7.58g
Flap Part 3 Right - 7g / 7.47g
Flap Part 3 Left - 7g / 7.49g
Total Weight - 38g / 41.94g
Jan 07, 2021, 10:18 AM
hager's Avatar
Ailerons Parts Weights
I weighed my ailerons for the wings. These were printed using Fillamentum PLA Crystal Clear Amethyst Purple, 1.75mm filament and the default 3DLabPrint processes in Simplify3D.
Aileron Part 1 Right - 6g / 5.91g
Aileron Part 1 Left - 6g / 5.87g
Aileron Part 2 Right - 8g / 9.05g
Aileron Part 2 Left - 8g / 9.01g
Aileron Part 3 Right - 8g / 8.93g
Aileron Part 3 Left - 8g / 8.85g
Total Weight - 44g / 47.62g
Jan 07, 2021, 06:12 PM
hager's Avatar
Elevon Parts Weights
I weighed my elevons for the wings. These were printed using Fillamentum PLA Crystal Clear Amethyst Purple, 1.75mm filament and the default 3DLabPrint processes in Simplify3D.
Elevon Part 3 Right - 4g / 4.30g
Elevon Part 3 Left - 4g / 4.18g
Elevon Part 4 Right - 4g / 4.30g
Elevon Part 4 Left - 4g / 4.21g
Total Weight - 16g / 16.99g
Jan 07, 2021, 09:28 PM
hager's Avatar
Canopy Parts Weights
This is the final print job. All prints completed with the recommended 3DLabPrint processes in Simplify3D.
I weighed my canopy parts. These were printed using Hatchbox PLA True Black, 1.75mm filament and the default 3DLabPrint processes in Simplify3D.
Canopy Part 1 Front- 6g / 7.72g
Canopy Part 2 Rear - 9g / 10.67g
Total Weight - 15g / 18.39g
Jan 07, 2021, 09:31 PM
hager's Avatar
In the next updates I will go over my review of the printing processes, post print processing, component selection and assembly.
Jan 07, 2021, 09:34 PM
hager's Avatar
Post Print Processing
Minimal cleaning was required using the 3DLabPrint profiles in simplify3D. A X-Acto knife and small needle files were all that was required to remove the brims and minimal supports. Parts fit is excellent and should provide strong glue joints and clean seams.
A word of caution, one should not use wire cutters or scissors to remove the brims or other supports in thin wall printed parts!
The shock will cause the layers to split and crack the delicate structure. Scoring with a knife and gentle flexing is all the is required.
Preparing for the hardware required a 1.6mm drill bit for the control horn clevis pin holes and a 3.3mm drill bit for preparing the holes to tap for the wing bolts using a 4x0.7mm tap.
Assembly will be done using BSI Insta-Cure+ Medium CA and BSI Insta-Set Accelerator.
Jan 10, 2021, 12:00 PM
hager's Avatar
All gluing was done with BSI Insta-Cure+ Medium CA and BSI Insta-Set Accelerator. No fogging or discoloration was encountered using these products. Next up will be installing the hinges, motor and radio installation.
Jokerwings.com has an excellent video of the assembly process:
JOKER - 3D printed RC plane - step by step assembly (21 min 11 sec)
Discussion 3DLabPrint Joker Hotliner Mozella 3D Printed Planes 55 Sep 18, 2021 04:44 AM
Build Log 3dlabprint big spitty build hawaiianspork226 3D Printed Planes 1 Jun 17, 2019 01:43 PM
Build Log Minicopter's Joker 3DD Build (w/ Slow Motion Video) Chachin Large Electric Helis 55 Jul 05, 2010 04:38 AM
Maxi Joker II build thread waug Electric Heli Talk 32 Sep 01, 2005 11:38 AM
Watch me build my Joker CX day by day Lv2Fly Electric Heli Talk 13 Jan 28, 2003 09:47 PM
