Dec 30, 2020, 06:32 PM
30cc Sbach 342 build
Hey all. New Sbach 342 getting closer to January maiden flight. First thing after after airframe arrived was check for damage and then start weighing components. Airframe from general hobby, arrived well pack and no damage with in a week of ordering.
Dec 30, 2020, 06:36 PM
Sbach 342
Was surprised it was a one piece tail for 30cc size airframe. Motor Iím using is Dualsky 5330.
Dec 30, 2020, 06:39 PM
Sbach 342
Using king max HV mini servos on ele and ale and blue bird A920 for rudder on 6.6v
Dec 30, 2020, 06:45 PM
Sbach 342
Many weight saving components installed with end goal of under 10lbs AUW and looking like this will be met.
Jan 14, 2021, 09:45 AM
Sbach build
Few ounces over 10lb goal but still far lighter than average 30cc Sbach build Iíve seen online so very pleased. And ZERO dead weight added to carry around, something Iím dead against doing. Should fly incredibly with AUW 10lb.4oz .
Jan 14, 2021, 09:53 AM
Sbach build
Reducing weight along the way by simply replacing full size servos with high torque minis which takes weight out of tail for CG replace gear mount bolts with aluminum versions, collars, dubro foam wheels 2/14 all aluminum washers, standoffs sourced from Mcmasters and very light compared to rc labeled standoffs. 850mah receiver battery no switch etc. every little bit will add up at the end just like saving money over time.
Jan 14, 2021, 09:56 AM
Sbach build
Haha wrong photo. Hi Dad. Standoffs from McMaster. They have great selection of components for your build.
Jan 14, 2021, 10:25 AM
San Antonio TX.
sensei's Avatar
Nice!
Bob
Jan 14, 2021, 10:42 AM
Late99's Avatar
Interesting project. Seems like I've got lot of questions.
What exact Sbach kit / ARF this is? What is the wingspan?
What ESC and what batteries (how many cells) you're going to use?
What about the exact motor model (KV)? What prop you're going to use?
Keep up good work!
Jan 14, 2021, 09:32 PM
San Antonio TX.
sensei's Avatar
Wing area?
Bob
Jan 23, 2021, 02:41 AM
30cc Sbach build
Hi Bob, itís a gold wing model 30cc size
Wing span 73Ē
1025 wing area
Running Dualsky 280kv on 8S with 19x8 falcon wood prop
Jan 23, 2021, 02:42 AM
[QUOTE=Quantitivequad;46381281]Hi Bob, itís a gold wing model 30cc size
Wing span 73Ē
1025 wing area
Running Dualsky 280kv on 8S with 19x8 falcon wood prop[/QUOTE
Esc is castle edge lite 100amp
Jan 23, 2021, 02:50 AM
Sbach
Maiden early next month
Jan 23, 2021, 08:36 AM
San Antonio TX.
sensei's Avatar
At that weight and wing area, that is going to be light on the wing and fly really great. Well done!
Looking forward to your flight report...
Bob
Mar 09, 2021, 07:11 AM
30cc Sbach
Well roughly month build and extremely happy with how this gold wing bird flys. CG 5 1/2 back, factory 4 7/8 back is very nose heavy and poor setup. Rock solid harriers and clean flat spins. Lands like a trainer at 5 1/2 back CG and completely neutral. Knife edge spins lock in with no mixes. Only problem Iím having is tail wheel wire connector to rudder is pulling out of collar so ordering another design from f3a unlimited to try. All in all one of the best planes Iíve ever flown. So any questions about general hobby gold wing arfs are gone. Very light just use your modeling skills were needed.
Build Log Pilot RC Sbach 342 30cc build thread jhasrac1 3D / Fun Fly Fuel Planes 345 Nov 27, 2017 12:15 AM
New Product Redwing RC 30cc Sbach 342 Build DoctorDaveDO Giant Scale Airplanes 25 Jul 08, 2014 05:04 PM
Build Log New Slipstream aircraft. The MXS 30cc and the SBACH 342 30cc cryhavoc38 Glow to Electric Conversions 12 Feb 06, 2012 10:52 PM
