Dec 24, 2020, 11:18 AM
Go Gondos
scale_only's Avatar
Build Log
Mig-3 by ESM
I was lucky to find the discontinued ARF two years ago,,, nice guy met me at the Last Toledo show,,, Has sat since while I slowly finished other projects,,, was up for sale,, you could have owned it, but no,, nothing but dreamers and tire kicker ever showed interest
I had a water heater line go a couple nights ago, caused some minor basement flooding,,, bottom of the box got a little wet, I had to toss it,, so that puts her to the front of the build line
Always loved the lines of the mig-3 since back in the mid 90's warbird racing days when I scratch built one based on the Romin Research plans,, sadly I never took pictures of that one
Anyway,, mocked her up to get some inspiration
Dec 24, 2020, 01:50 PM
Lucky man you are!!
Dec 24, 2020, 02:37 PM
Go Gondos
scale_only's Avatar
Yes,, I am thankful
Dec 24, 2020, 02:52 PM
Go Gondos
scale_only's Avatar
Decided to start in the tail and work my way forward,,
Noticed something interesting,, the covering is clear iron on,, then painted after,,, this is great because I plan to do a scheme modification and some weathering,, I should be able to paint right over this with very little prep,, might go with a winterish camo like the second one in the picture below
Things I don't like,, CA hinges,, C'mon man,, no way,, Robarts going in
The bell crank has to go, Lost my World Models Zero to a similar system that failed,, even though this is pull pull,,, naah don't think so,, started adding servos in the tail for elevators Hitec 5645mg should do the job just fine
as you can see,, screwed up already,, miss calculated how large the hatch can be
Servo and mounting hatch is a tight squeeze,, but I got her in there,, the other side should go more smoothly
Will need to fill that little gap between the hatch and cut out before I repair the covering,,, no biggie,
Dec 24, 2020, 03:53 PM
Prekin's Avatar
I will follow your project!!
Dec 24, 2020, 06:04 PM
Go Gondos
scale_only's Avatar
Cool,, Glad you're on board Jiri,,, Did you make the Spinners VQ now Legend sells for these?
Dec 25, 2020, 03:15 AM
Prekin's Avatar
ESM kits were/ are great flying! I had their Stuka, Dauntless and La-7.
I did spinner for the La-7, but I am not sure about the right shape for MiG-3
Dec 25, 2020, 04:05 AM
Prekin's Avatar
I looked at the spinner. If you will not find any designed for MiG 3, you may use some for P-40. The shape is very similar.
What engine will you use?
Dec 25, 2020, 06:48 AM
Go Gondos
scale_only's Avatar
Yes, the p-40 shape looks to be very close, I already have bought a Dave Brown spinner,, was just curious and if I go with a 3 blade, that would be an option
Engine most likely will be a DA50s
Dec 25, 2020, 10:15 AM
Mptolomey's Avatar
Are you going to convert it to a 3 piece wing? Who’s retracts...
Dec 25, 2020, 10:20 AM
Mptolomey's Avatar
I have a DLE55RE in my first that flew the plane fantastic... I also found a NIB not too long ago, I will put a DLA-64 in that when I get to it.
Dec 25, 2020, 11:24 AM
Go Gondos
scale_only's Avatar
I thought about it,, but probably not, 80" span is no big deal for me
I plan to use a set of Robart 630 series I hav that are already converted to EP with Lado actuators, just will need straight struts
Cool,,
Dec 25, 2020, 11:37 AM
Go Gondos
scale_only's Avatar
Cleaned up the gap on the one hatch and got the other done this morning
I don't like the gap and the fact where the tube goes through is just thin fiberglass,, made a couple ply plated to reinforce that area,, going to be tricky getting them back there, but I can get my hand back there,
Dec 25, 2020, 12:09 PM
Prekin's Avatar
This thread is like a torture for me! I wish to find some other ESM kits NIB.
I had ROTO 35 in my ESM La-7. Perfect for scale flying! TOW was about 7,5kg and after remake 8,3kg.
Dec 25, 2020, 04:53 PM
Mptolomey's Avatar
I was lucky to find a NIB ESM P40 last year, halfway though that build with a Roto 85FSI
https://www.flyinggiants.com/forums/...d.php?t=281245
Build Log Mig 3 in 1/9 scale by FokkeRC Fantasmos Scale Kit/Scratch Built 3 Jun 13, 2019 09:18 PM
Build Log ESM Mig-3 Dangerous_toys Fuel Warbirds 110 Oct 16, 2015 11:37 AM
Help! Esm mig-3 scoobiemario Fuel Warbirds 12 Sep 16, 2015 06:32 AM
Question has anybody seen a video of the MIG-3 by TDM models ? sebbe Electric Warbirds 10 Nov 03, 2009 09:12 PM
