Dec 24, 2020, 04:07 AM
dimas_71's Avatar
Strange throttle channel behavior
I noticed that the values ​​of the throttle channel are constantly changing within + - 0.1 0.2. Is this normal or not?
Radio MZ-32
Firmware 1.043
24 декабря 2020 г. (0 min 4 sec)
Dec 24, 2020, 09:33 AM
ARCS 1980's Avatar
The video is too short to examine. Try 10 seconds long next time. Please re-do this video with your smartphone turned to a landscape mode plus center the Tx screen on it. All that is seen mostly is the neck strap bracket and on up. OTW, video quality is very good.
Dec 24, 2020, 10:17 AM
dimas_71's Avatar
24 декабря 2020 г. (0 min 11 sec)
Dec 24, 2020, 02:06 PM
Have you tried a stick calibration?
Dec 24, 2020, 02:39 PM
dimas_71's Avatar
Yes, I calibrated the stick
Dec 27, 2020, 02:22 AM
dimas_71's Avatar
I would like to hear the opinion of the developer, is this normal or not ?!
Dec 27, 2020, 05:09 AM
I don't recall my radio doing this. Does yours do this at any throttle position, or just the one shown?
Dec 27, 2020, 07:14 AM
dimas_71's Avatar
At + -100%, 0% - there is no change in values, in the range 10% - 90% there are constant changes in the value.
I watched another mz-32 radio - the same....
Dec 27, 2020, 12:00 PM
Paper Plane Scratch Builder
Lufo's Avatar
If you go back to previous FW does problem clear up?
I suspect there are one or two things happening. The software is probably more sensitive and is sampling the stick positions more frequently; this increased sampling will find manufacturing irregularities in stick components that were not previously known to the user of the previous FW version.
I think the big question is this...does it affect the throttle when plane is powered up on the ground or when flying? If it does not then I would not be so concerned but would file an official bug or unexpected event report with Graupner.
This is interesting as another user had a FW upgrade fail due to an issue with a "right switch" assembly. Apparently the FW software is now more sensitive or it is 'testing' assemblies for state of presence.
Dec 27, 2020, 12:55 PM
dimas_71's Avatar
Firmware 1.038 is the same (
Dec 27, 2020, 01:06 PM
Lufo's Avatar
Ouch! Sorry to hear that. So have the radio always done this or is this a new event? At best guess, it is hardware issue so if this is
affecting the control of the plane then you can return to Graupner and request warranty work.
Past sending this back to Graupner, you can open the case up and check for look connection and use something like an air dust blower for
camera lens and blow clean all you can from the board and components. Granted that is a long shot but can not hurt to try.
Dec 27, 2020, 01:28 PM
dimas_71's Avatar
I see another mz-32 - the same, change values in throttle stick.
Dec 27, 2020, 01:35 PM
Lufo's Avatar
Yes...I saw that as well. So since, you move back to previous version and problem still exists then it is perhaps a hardware issue?
As for the latest version, a software increased sampling rate for controls could detect problems not previously known. Also new version may have a bug in a math value that is causing an erroneous display.
If I remember correctly my MC-20 did the same but it never affected the controls. Are you having any control issues?
Dec 27, 2020, 05:01 PM
This behavior you will see on the throttle channel mainly because it is not locked mechanically (springs) into place like the other channels.
These small deviations readings are not mechanical but probably more of a an attempt by the software to determine the position of the stick.
I will forward this to the developers and check if they can alter a bit the way they calculate and display stick position.
Help! DX9 throttle stick strange behavior xiaoyu80305 Radios 1 Aug 27, 2016 01:01 AM
Discussion Help! Strange power/throttle issue! Quaddude88 Multirotor Drone Talk 19 Feb 16, 2016 02:40 PM
Discussion B400 Strange Throttle Hold Behavior DannoK Mini Helis 14 Sep 18, 2010 04:35 AM
Discussion strange throttle behavior michael503 Electric Power Systems 5 Oct 15, 2007 09:49 AM
Discussion Eclispse 7 Heli mode low throttle strange behavior kenny_dilger Electric Heli Talk 10 Jun 17, 2006 04:18 PM
