Dec 01, 2020, 06:31 PM
Help!
TX for AR9200
I just got a 50cc plane and it has a AR9200 rx in it. I have a dx8 tx that wont bind to it. Will a dx9 tx work with this rx?
Dec 01, 2020, 06:35 PM
Sagitta Fanboy
All 3 DX8's and DX9 will bind to a DSM2 receiver like the AR9200. It's only the DXe and EU-spec transmitters that don't.
Often corroded connectors on the remotes can cause issues. Note the AR9200 is a PowerBox evolution combined with DSM2 remotes. It does need all 3 remotes plugged in and responding to work.
Dec 02, 2020, 07:46 AM
Thanks for the reply. My concern is that its an AR9 that it needs at last a 9 channel tx. I will check the wire connections and give it another try.
Dec 02, 2020, 08:14 AM
AndyKunz's Avatar
No, it doesn't need a 9-channel transmitter. It will work with any DSM2-capable transmitter from DX6e through iX20.
It needs a remote receiver. Do you have that attached?
Andy
Dec 02, 2020, 08:17 AM
Good to know. It has three remote receivers attached.
Dec 02, 2020, 09:10 AM
68 years an RC flyer
Daedalus66's Avatar
As Mawz said, the most common problem is dirty connectors. Remove the cables and replug at both ends. I also like to spray on some contact cleaner.
When working correctly, the main receiver and all remote receivers will flash rapidly when in bind mode.
Dec 02, 2020, 07:18 PM
I got it to work. The forward remote rx plug was not in all the way.
Thanks everyone for the help.
Jan 23, 2021, 07:22 PM
So I wanted to send my AR9200 in for a check up to see if it was in good working order but I was told that HH doesn't work on these anymore. I did the bind thing to this like 6 or 8 times now and no issues. Mover the wires around and no issues. Haven't done a range check yet but I will. Is there any reason to think this rx would not be reliable? I know there is no guarantee.
Jan 23, 2021, 08:31 PM
Sagitta Fanboy
If it passes range check, you should be good.
There's never a guarantee, but a range check is the best test.
Jan 24, 2021, 10:28 PM
Daedalus66's Avatar
The DSM2 receivers with remotes are still excellent. I have used AR6200 and AR7000, as well as JR DSM2 receivers in older models for years without any problems whatsoever. Only in difficult RF conditions would I worry about their reliability compared to DSMX. Or with high value models.
Discussion Looking for 5.8gHz video TX for Aerial Photo work..recommendations? Canada Goose FPV Equipment 9 Mar 13, 2020 12:52 PM
Question Optimal camera/TX for best headset image (TVL#, AR, CCD/CMOS, TX)? Kurt FPV Equipment 5 Apr 18, 2016 01:48 AM
Question Futaba 10C, what Tx module and RC Rx do I need for PPM capable for a VortexPRO????? LexusFPV FPV Equipment 0 Dec 13, 2015 03:29 PM
Discussion Cradle for the tx for screen? razorseal Radios 1 Nov 18, 2015 10:37 PM
