Servo frame screws strip too easy
What size of phillips head screw driver do you use for the tiny servo frame screws?
Do I need to buy a set of Japanese phillips head screw drivers? All of the American phillips head screw drivers are too loose and the head of the screw gets stripped out. Any suggestions? The frames are already glued into the wing of my Big Flap Xplorer. Thanks in advance ! |
I purchased a set of the Japanese phillips head screw drivers years ago and love them, and yes, IMHO they make a big difference when installing servo screws and other hardware.
Very little oil on the screw helps a lot to reduce drag.
If the head of the screw is stripped, you likely have to use a pair of good pliers (e.g. assembly pliers) to get the rotation (back out again) started. It has happened to me a few times.
Bernd's suggestion is a good one. Another (I learned from my grandfather many decades ago) is to scrape the screw thread across a bar of soap before you first try to screw it in - soap is a pretty good lube for stuff like this, since it is largely fat. And/or drill the hole as large as seems reasonable, first. |
Thread Tools | |
Similar Threads | |||||
Discussion | Micro servo screws too long | rhodesengr | Radios | 5 | Sep 07, 2016 02:45 PM |
Help! | I think I stripped the servo screw | Ashex | Electric Power Cars | 5 | Sep 14, 2014 01:29 PM |
Discussion | stripped 450 frame screws. | LiQuid*Xion | Electric Heli Talk | 14 | Jun 23, 2012 11:59 AM |
Discussion | Align SE Frame Screws???? Are they stripping for everyone or just me????? | [email protected] | Mini Helis | 7 | Mar 27, 2006 01:25 PM |
@!#$ Stripped mini servo screw!!!! | WrongwayFeldman | Parkflyers | 4 | May 12, 2002 06:17 PM |
