Thread Tools |
This thread is privately moderated by GroundControlRC, who may elect to delete unwanted replies. |
Video
Volantex Sport Cub 500 RTF w/Gyro - Aileron Extension Test Flights![]() Volantex Sport Cub 500 RTF w/Gyro - Aileron Extension Test Flights, My Quest for a better Roll Rate! Volantex Sport Cub 500 https://www.banggood.com/custlink/DmGmUiY16o Banggood GCRC https://www.banggood.com/custlink/GmDmQ1nVkO Here is a link to the Video: https://www.youtube.com/watch?v=h0YKErAzswA Even in Manual Mode the Roll Rate is a bit Slow! I added Aileron Extensions to try and get a better Roll Rate. It worked great on the Eachine Mini F4U Corsair, will it work on this Plane? You Can Help Support Us By Using Our Affiliate Link To The Product Below. A small commission (At No Cost To You) helps us buy more items to review. Volantex Sport Cub 500 https://www.banggood.com/custlink/DmGmUiY16o EXHobby / Volantex https://www.exhobby.com/us/products/...=5e824f89734c4 Here is a link to the Playlist for the Volantex Sport cub 500: https://www.youtube.com/playlist?lis...khCQwKy5do3Bs8 Spare Parts: ***These Parts are for the Eachine Mini P51D Mustang but I believe they are compatible. Lipo Battery 1S 360mAh for Eachine Mini Mustang P-51D RC Airplane https://www.banggood.com/3_7V-360mAh...47791920140372 Eachine 3.7V 380mah 25C Lipo **I use these in the Eachine Mini P51D Mustang with no problem https://www.banggood.com/Eachine-3_7...47791920140372 JJRC H31 RC Quadcopter Spare Parts Battery 3.7V 400mah https://www.banggood.com/JJRC-H31-RC...47791920140372 JJRC H31 RC Quadcopter Spare Parts 6Pcs 3.7V 400MAH 30C Battery and Charger Set X6A-A13 https://www.banggood.com/JJRC-H31-RC...47791920140372 5PCS 3.7V 300mAh Lipo Battery Set for H8 H22 Eachine H8 Mini RC Quadcopter https://www.banggood.com/5PCS-3_7V-3...47791920140372 5 x 3.7V 300mAh 45C Battery With 1 to 5 Charger Eachine E55 FQ777 FQ17W https://www.banggood.com/5-x-3_7V-30...47791920140372 Brushed Motor 10mm Hollow Cup for Eachine Mini Mustang P-51D RC Airplane https://www.banggood.com/10mm-Hollow...47791920140372 Prop 130X70mm Propeller Set for Eachine Mini Mustang P-51D RC Airplane https://www.banggood.com/130X70mm-Pr...47791920140372 Gearbox for Eachine Mini Mustang P-51D RC Airplane https://www.banggood.com/Gearbox-for...47791920140372 2PCS Eachine Mini Mustang P-51D RC Airplane Spare Part Rudder Angle https://www.banggood.com/2PCS-Eachin...47791920140372 Video that discusses how to balance a Brushed Motor Prop - Tips - MinimumRC F8F Rare Bear Pro Build & Setup (Time Code 1:29) https://www.youtube.com/watch?v=uENTA7OlpdY #GroundControlRC #GlueAndFly #ScratchBuildPlanes #VolantexSportCub500 #SportCub500 #SportCub #SuperCub500 #SuperCub #Cub #V761 #V765 See you in the Air! Build, Fly, Crash, Repair, Rinse & Repeat! Ground Control RC™ Glue & Fly™ Series Scratch-Build Planes Consider Supporting Our Channel by becoming a Patron at: https://www.patreon.com/groundcontrolrc Patrons of the Channel will have access to the latest Aircraft Plans & Exclusive Content! See Us On Youtube | Patreon | RCGroups https://www.youtube.com/c/GroundControlRC https://www.patreon.com/groundcontrolrc https://www.rcgroups.com/forums/member.php?u=754189 |
