Thread Tools |
This thread is privately moderated by Jim.Thompson, who may elect to delete unwanted replies. |
Hybrid construction method.
I have just finished building the wings for my Kaos hack aerobatic electric powered model.
The method uses a tapered carbon tube and was inspired by the current generation of F5J sailplanes, which commonly use a parallel tube I think. I made the tube using a pool cue as a mandrel. Layup for the tubes was: 1 inner layer of 60 gsm plain weave glass fabric on the bias. 1. layer of 300 gsm uni-directional carbon. 1 layer of 100 gsm plain weave bias oriented glass fabric on the outside, mainly to provide some torsional stiffness and to hold it all together. The foam ribs were all cut together using the so called "laser method" and the holes to take the spars were all cut the same way. A pilot hole was roughly cut to thread the hot wire through before power was applied and it was then guided by hand around the inside of the holes in the end templates. Spars glued to the foam ribs with PU glue. 1mm balsa caps glued to the ribs with white PVA glue. 3mm Pauwlonia sub LE first, then a final 6 mm Pauwlonia LE glued on after the caps were all fitted and trimmed. The construction of the flying surfaces is all described elsewhere------I think? Pintle and gudgeon hinges, otherwise known as "Pocket Hinges". 2 mm carbon rod pintle. 30 micron laminating film covering. Nice stuff to use!.......Dirt cheap and very strong. Jim. ImagesView all Images in thread
Thread Tools | |
Similar Threads | |||||
Question | Lightest Construction Method? | toren_andersen | The Builders Workshop | 30 | Apr 08, 2020 09:39 PM |
Question | Lightest RC Plane Construction Method | toren_andersen | Electric Plane Talk | 4 | Mar 18, 2020 10:35 AM |
Discussion | Mig-3 Inspired - Alternative construction method | farmertom | 3D Printed Planes | 34 | Nov 27, 2018 07:44 PM |
Help! | Foam Wings... Construction Methods? | Ranald | The Builders Workshop | 20 | Mar 20, 2017 04:12 PM |
Discussion | EPP construction methods - "Japanese Style" | PabloM | Foamies (Scratchbuilt) | 3 | Jan 31, 2016 05:41 PM |
