Alert
Timber stab tube failure
I found a loose stab on preflight caused by a broken CF stab joiner. I separated the 2 pieces and used the shattered ends as ends for the tube . I used CA and Monocote backing to glue the cracks shut. I found an inner CF tube and turned it down with 80 grit paper while spinning it in a Dremel. I used about 1.5 inches to joine he 2 clean ends together using CA.
I has to insert the repaired tube into the plastic fuselage hole one way as there was a repair bump that restricted entry. This plane and parts are discontinued so parts are hard to get |
Thread Tools | |
Similar Threads | |||||
Question | Timber X servo adhesion failure | sky5900 | Parkflyers | 3 | Dec 29, 2019 04:37 AM |
Discussion | Servo failure E-Flite Timber airleone | Chuck felkins | Beginner Training Area (Aircraft-Electric) | 3 | Jul 27, 2019 11:59 PM |
Discussion | UMX Timber Servo Failure | DFREDB | Electric Plane Talk | 3 | Oct 12, 2017 06:23 PM |
Help! | Super AVA V Stab Support Pivot Tube Size | old1104 | Sailplane Talk | 1 | May 12, 2016 12:30 PM |
Discussion | Loose fitting horizontal stab tube...cure? | palmsp9 | Giant Scale Airplanes | 1 | Jan 17, 2016 09:59 PM |
