Nov 25, 2020, 03:34 PM
Where's Pamela?
patmat2350's Avatar
Invader Tug by patmat2350
Look what just showed up at the ranch!
From Harbor: https://www.harbormodels.com/har105.html
Nov 25, 2020, 03:36 PM
Where's Pamela?
patmat2350's Avatar
This isn't the first Invader thread here, which is lucky for me- I can learn from previous builders.
MassSailor's zombie thread, but what a good start: https://www.rcgroups.com/forums/show...ls-Invader-Kit
Longbike's build: https://www.rcgroups.com/forums/show...ader-tug-build
TugNeil: https://www.rcgroups.com/forums/show...-Invader-Build
others?
Nov 25, 2020, 03:46 PM
Where's Pamela?
patmat2350's Avatar
There'll be a fair amount of head scratching and a few more boxes of parts before I get started. First order of business- does anyone have better Invader plans? I saw a couple references to plans adequate to scratch build from, and these ain't them:
Nov 25, 2020, 03:51 PM
Where's Pamela?
patmat2350's Avatar
There are plenty of photos out in the interwebs... a whole bunch of hi-res images can be found if you're logged in at Shipspotting.com. I've grabbed over 100.
Nov 25, 2020, 05:31 PM
The Grey Seas Under
TugPower's Avatar
Great, an ocean going tug, my favorite ship model or otherwise.
Looking forward to the build Patmat.
Nov 25, 2020, 06:17 PM
Jerome Morris's Avatar
Looking at the “ plans” it almost screams out a need for a lot of photographs.
Nov 25, 2020, 06:27 PM
On Or Under The Water
Tug Fan's Avatar
others?
Tugneil's ended just after it started.
Nov 25, 2020, 06:32 PM
Tug Fan's Avatar
You must finish the Hillman. I'm running out of popcorn.
Nov 25, 2020, 06:46 PM
Where's Pamela?
patmat2350's Avatar
May need a breather
Nov 25, 2020, 06:47 PM
The Grey Seas Under
TugPower's Avatar
I just went over Harbor Models specs on Invader and she will be a beast of a model once finished, I'm guessing final weight will be 60 plus pounds if not more, pretty impressive model and she will look great in the water, she is to scale water is not.
Nov 25, 2020, 06:57 PM
Where's Pamela?
patmat2350's Avatar
I've seen mentions of 75 pounds
Nov 25, 2020, 07:24 PM
The Grey Seas Under
TugPower's Avatar
Back brace and scooter might come handy.
Nov 25, 2020, 07:31 PM
Where's Pamela?
patmat2350's Avatar
I rarely work from full size (model size) plans... and with a beast like this, the plans are really too much! So I folded them for occasional reference, and printed out photos on letter size sheets for frequent reference.
I can't imagine why someone would bother drawing up plans like this and not include at least a few useful dimensions. Like:
- The straight line of the bottom rises at 1.6į relative to the waterline (had to do some trig)
- The line up to the transom (stern counter) rises at 17į relative to the bottom.
- The deadrise angle near the rudders is about 14į (each side), but the bottom is built a bit convex. Still, useful to know when designing new rudder bases (the kit parts are all wrong).
- Prop shaft centerline is drawn parallel to the bottom (not a given!) and is 2-5/8" above the bottom.
- No indication is given for prop spacing. But 3 circles are drawn on the aft deck which look like rudder post access hatches, and these are spaced 3-5/32" to either side. These probably line up with the prop centers.
Nov 25, 2020, 08:10 PM
The Grey Seas Under
TugPower's Avatar
I have to agree, they are barely a general reference.
Nov 25, 2020, 08:53 PM
r/c ships and workboats
Pat, I have copies of the original drawings and photos of the boats from up here. There are different arrangements depending on whether you want to build the tropical, coastal, or Alaskan ( Valdez) versions.
Build Log Invader Tug build continued Bermie Scale Boats 5 Feb 12, 2013 09:46 AM
Discussion Tug Invader Tom_Tugboat Dock Talk 18 Jun 29, 2012 12:59 PM
Discussion Tug Invader and a floating drydock sink Tregurtha1013 Dock Talk 88 Apr 14, 2012 04:42 PM
Discussion Invader Tug BUTTERWORTH Scale Boats 49 Mar 26, 2011 02:57 PM
Build Log Invader tug build LONGBIKE Scale Boats 100 Jul 03, 2010 07:41 AM
