This thread is privately moderated by pwkpete, who may elect to delete unwanted replies.
Nov 21, 2020, 03:09 PM
Trader Rating: 45
unRegistered User
$20.00 USD
Seller Pays Shipping
For Sale
TP-535, TP-205v, Power supply
I have lightly used TP-535 setup. It comes with the matching TP-205V balancer and data cable. I'm also tossing in a 1.6A power supply for free.
I have it at 20$ shipped for the works, it is just over 1lb so it would go priority.
If you don't want the PS, I could send it via first class and would drop the price to $17.
Contact me via email in the forum here or this page: https://www.elektrorc.com/contact_us.php.
From the manual (http://www.sgbotic.com/products/data...C-manual.pdf):
<Features>
① Ultra high-speed digital power system
② Light weight and fully capable of charging up to 3500mA and 5cells in series.
③ Easy setting for various battery pack parameters.
④ Reverse polarity protection circuitry (INPUT/OUTPUT)
⑤ Easy monitoring indicators (current and voltage charge status)
⑥ Beeps will sound to alert you with errors in the charging conditions or when charge is completed.
⑦ Safe mode automatic cell count (1-4cell).
⑧ Overcharge protect with TP balancer connected.
<Specifications>
① Input Power source: 11V-15VDC requires 5A current rate at maximum charge rate.
② Charge Voltage:3.7V-7.4V-11.1V-14.8-18.5V( 1cell-5cells in series )
③ Charge Current: 500mA-1000-1500-2000-3000-3500mA
④ Full charge voltage: 4.2V per cell
⑤ Overcharge cut off voltage:4.3V/Cell
⑥ Maximum output power:45Watt
⑦ Size:1.62” x 4” x 0.62”(42mm x 102mm x 16.2mm)
<Charge steps>
① Connect 12VDC power to the INPUT DC-JACK(Red:+ Black-)
② Connect Lithium Polymer battery to the “OUTPUT” terminal(Red+ Black-)
③ If you have TP205(V) or TP210V, please connect the data cable at both-ends between the TP535
data port to the balancer as shown in picture-2.
④ Select the appropriate amount of charge current rate.
⑤ Select cell count.
⑥ Press “Start/Stop” button.
⑦ The charge yellow LED will begin flashing.
⑧ When the Full LED (Green) is solid ON, charge has been completed
Today, 10:01 PM
Trader Rating: 27
wedoitall's Avatar
can I have this !
For Sale Thunder Power TP-535 Charger, TP-205V Balancer and DL-250A Data Link Cable Cypher7 Aircraft - Electric - Batteries & Chargers (FS/W) 4 Aug 21, 2018 03:11 PM
Sold Thunder Power TP1010C Super Charger, TP-205V Auto Balancer & TP-PGM-V2 Programmer Red Baron Mike Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jun 08, 2018 04:37 PM
Sold Thunder Power LiPo TP1010C Super Charger, TP-205V Auto Balancer, TP-PGM-V2 Programmer Red Baron Mike Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 30, 2018 08:55 PM
For Sale Thunder Power TP-535 Charger & TP-205V Balancer kdill2160 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jul 11, 2010 09:51 AM
Discussion Thunder Power TP-535 and TP-205V pdansalvish Batteries and Chargers 3 Sep 20, 2009 08:26 PM
