This thread is privately moderated by NobatteryNopower, who may elect to delete unwanted replies.
Nov 21, 2020, 11:48 AM
NobatteryNopower's Avatar
Build Log
Balsa Super Alula | Update
I've been slowly working towards a maiden with the balsa Super Alula FV plane. I've build a drop-pod like camera structure to mount underneath the wing. On the other side of the fuselage I placed the VTX with the heat sink on the underside. The RHCP antenna is removable for transportation.
To do:
- Cover the bottom of the wings with Hobbyking clear covering.
- Remove some covering so glueing the fuselage to the wing won't be a problem.
- Remove some covering so glueing the camera pod to the underside of the wing won't be a problem
- Mount the flightcontroller
- Mount the TBS nano receiver + antenna
- Make balsa top fuselage covers
- Mount horns & clevises
- Maybe paint the fuselage and tail section white so moisture stays out of the balsa parts.
Build Log new BVM conversion... Super Balsa Bandit... update ;) ralf dvorak Electric Ducted Fan Jet Talk 82 Aug 23, 2009 10:02 AM
