Nov 19, 2020, 07:17 PM
Tony Audsley Retired Locksmith
Lockey's Avatar
Build Log
Fixler ... a 3D printed fuselage for your Bixler wings
Hi guys ... how many of you guys (like me) have a set of Bixler Mk2 wings and no fuselage ?
Its been crashed so many times the fuselage is no longer reparable but the wings are fine
I might have a fix for you .. "Fixler" .. a 3D printed fuselage .. I am just testing it and if it turns out OK, I will have the G-Codes and STL files available for sale for you to print your own
I am using (and would recommend) LW-PLA .. its much lighter and more durable than PLA or PET-G
Lockey
NOW AVAILABLE ...
Files are now ready and available here ... https://www.lockeysrcplans.com/produ...ixler-fuselage
Also on Cults .. https://cults3d.com/en/3d-model/vari...bixler-2-wings
Lockey
Nov 19, 2020, 07:27 PM
Oh wow, that's going to be so good.
Signed up and waiting. Thanks
Nov 20, 2020, 09:05 AM
formontoya's Avatar
subbed & waiting...
Nov 20, 2020, 08:39 PM
Lockey's Avatar
Successful maiden this morning .. I added a strip of fiberglass tape to the underside to help it slide on the grass
Lockey
Fixler Maiden (5 min 30 sec)
Nov 20, 2020, 09:07 PM
Retired CAD guy
birdofplay's Avatar
Lockey,
Bravo !
You are really hitting into your stride!
Great work on this one.
I have a Multiplex Easy Star and the Easy Glider too - both similar to the Bixlr in many ways.
The LW-PLA is perfect for this application too.
I might the to reserve some Printer time for this one !!!\
This one is going to be a real winner!
So , Now that you are into the warm season ,
GET OUT THERE and Fly that thing a BUNCH !
Best
Bob
Nov 20, 2020, 09:16 PM
Lockey's Avatar
Originally Posted by birdofplay
Lockey,
Bravo !
Best
Bob
Thanks Bob .. you know it flew so well, I think it might even be OK made from PLA+ ( more colours and cheaper to print) I will give it a try I think ... might have to just lengthen the nose a little to compensate for the extra tail weight
I just have to tweak the drawings and files a bit and it will be ready
Later I will post all the build photos and maybe make a build video
By the way .. I used my new "slip lock" joint system too, so if one section gets damaged you only have to reprint that section and swap it over .. this one is in 3 sections
Lockey
Nov 21, 2020, 12:58 AM
Shouldn't that be your "slip lockey" system
Nov 21, 2020, 05:34 AM
Lockey's Avatar
Nov 21, 2020, 10:14 AM
Ray
That's incredible! Makes me want to go out and buy a pair of Bixler wings. You are really advancing the state of this hobby.
Ray
Nov 21, 2020, 10:41 PM
Lockey's Avatar
Ray
And they are so cheap .. only US$17.39
Lockey
Nov 22, 2020, 06:18 AM
Lockey's Avatar
I decided I would test print the modified parts with PLA + this time, to see what the weight is like and check out the files
I thought I would mix and match some colours (can't do that with LW-PLA) so ... just because I can .. haha
I made a video of the build (putting the parts together) I will post when its edited and sent to YouTube
Lockey
Nov 22, 2020, 06:43 AM
Jockadopolus's Avatar
Great work Tony
Now all you have to do is fit a set of wide undercarriage and a mast with rotor head and you have an Autogyro
I will get you to do another Autogyro one day
Joe
Nov 22, 2020, 07:24 AM
Lockey's Avatar
Here's part 1 of the build video
Lockey
Building the Fixler fuselage Part 1 (22 min 30 sec)
Nov 22, 2020, 07:59 AM
Lockey's Avatar
Originally Posted by Jockadopolus
Great work Tony
Joe
maybe one day Joe
Lockey
Nov 22, 2020, 06:21 PM
Lockey's Avatar
Her's part 2 of the Fuselage build
Lockey
Building the Fixler fuselage Part 2 (24 min 2 sec)
Nov 22, 2020, 08:01 PM
Luke2000
Tony sent me a trial piece for the Fixler. Wow is all I can say. I'm currently printing a seaplane which is proving very difficult to print without large gaps (in a seaplane ��), and another well known online seller which is going well, but not as good as this print. I've done the piece in std PLA, it's strong, light and smooth. Clevery designed for strength.
Well done Lockey, masterful.
(I don't have spare Bix wings but ordered them there tonight after printing!)
Luke
Nov 24, 2020, 05:50 AM
Lockey's Avatar
Here is Part 3 video
Lockey
Building the Fixler fuselage Part 3 (4 min 24 sec)
Nov 24, 2020, 05:59 AM
Super slick. Can you also do a video on how to keep a workshop tidy . You could instantly find the screws that you needed and you put the stuff back after . Hmmm
Nov 24, 2020, 06:41 AM
Lockey's Avatar
Thanks Luke
Here is part 4 and Part 5 .. and its now ready for the maiden
Weight before battery 843 grams for the PLA+ .. against 709 grams for the LW-PLA .. I was surprised it was only 134 grams difference .. it has a 30mm longer nose too
I used 6mm Depron for the tail parts
The PLA+ one .. flying weight is 1010 grams (thats just a tad over 1 kg) with a 2200/2s battery .. I am using the same motor as the LW-PLA one .. Turnigy D2826-10 1400kv
Lockey
Building the Fixler fuselage Part 4 (21 min 11 sec)
Building the Fixler fuselage Part 5 (21 min 35 sec)
Nov 24, 2020, 08:56 AM
EDF rules... :)
AirX's Avatar
Nice work! ATM I have a Bixler that has a broken fuselage that i picked up at a club trade day. i was thinking of doing somehting like that but now I dont have to.
Thanks Lockey.
Post the link so I can buy a set of files from you.
Cheers, Eric B.
Nov 24, 2020, 09:14 AM
Lockey's Avatar
As soon as I fly this beasty I will organise the files .
I will supply G-Code files to print directly to your printer for both PLA and LW-PLA and also STL files for the guys who would prefer to slice the parts themselves
Lockey
Nov 24, 2020, 09:17 AM
EDF rules... :)
AirX's Avatar
I print only ABS so STL will be fine.
Eric B.
Nov 24, 2020, 09:28 AM
Lockey's Avatar
Eric B.
Mmmmm interesting, look forward to seeing your parts
Lockey
Nov 24, 2020, 10:48 AM
Retired CAD guy
birdofplay's Avatar
I found this on Thingiverse ...
https://www.thingiverse.com/thing:2905612
scroll for the movie
Nov 24, 2020, 11:04 AM
Oh nice. I bought one, but lost some of the parts. Next print so, thanks
Nov 25, 2020, 03:51 AM
Lockey's Avatar
Here is the Maiden of the PLA model ... lack of power .. very strange .. decided to hand launch .. after the flight I changed the battery and the prop and tried again .. it was totally different ..
Lockey
Fixler PLA Maiden (4 min 44 sec)
Nov 25, 2020, 03:59 AM
Lockey's Avatar
I have a small problem.. after the flight with both models .. I fund that the motors were moving around ..
It seems that the heat from the motors had softened the plastic motor pod and was allowing the motor to move .. maybe thats what the noise was when I took off with Fixler 1
Fixler 2 seemed OK but when I landed I checked it and found it was the same
Not sure what the answer is ?? make from PET-G or ABS ? ... Put a ply sandwich each side of the mount area ? any ides guys ??
Lockey
Both Fixlers (5 min 23 sec)
Nov 25, 2020, 05:01 AM
Tony ABS mount and cooling duct like the BD5 might do it.
Or a ply firewall between the motor and plastic, isolate the motor screws from the plastic.
Joe
Nov 25, 2020, 05:18 AM
Lockey's Avatar
Joe
Yes Joe, thats sort of .. what I was thinking .. I have cooling through a hole in the motor tower and holes in the back of the motor mount for through cooling .. see pic
Lockey
Help! 3D printed fuselage for B-1B twin 70mm or above edwen303 Electric Ducted Fan Jet Talk 0 Sep 03, 2018 12:34 AM
Discussion 3d printed Airwolf Fuselage for 250 size heli scousethief 3D Printing 1 Jan 02, 2018 12:12 PM
Discussion 3D printed fuselage flies with foam wings. basicguy 3D Printed Planes 19 Oct 26, 2017 09:12 AM
Help! 3D printed fuselage Rahul95 Composites Fabrication 2 May 01, 2016 11:43 PM
Discussion What are the most useful parts you've 3D printed for your RC gear? Cinetography Multirotor Drone Talk 0 Mar 05, 2016 01:27 AM
