This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Nov 18, 2020, 07:31 PM
old4570's Avatar
Micro Tundra 1306 on video
Micro Tundra gets a 1306 (2 min 11 sec)
I soldered the motor directly to the ESC ( Lose some weight )
Everything seems fine , still using the factory ESC since the 6030 pulls a little over 5A
Test bench results =
6040 King Kong MT Prop - 6.8A - 55Watt - 8900 rpm - 180 grams
6030 Gemfan - 5.5A - 44W - 11500 rpm - 192g ( Not the same 6030 used on the 1106 )
5040 GF - 5A - 41W - 12000 rpm - 168g
6x4E - 6.6A - 52W - 9100 rpm - 180g
5045 - 5.5A - 43W - 11500 rpm - 162g
Hmmmm , well ! On the test bench it did 190 grams of thrust .. But in the Tundra ?
Anyways , there is a 1306 in my Micro Tundra now .
Nov 19, 2020, 09:59 AM
Fly Eat Sleep Repeat
Andy852's Avatar
I got myself a 1306 from HobbyKing today and a 6A Esc which I plan to wire directly also and shorten then wires for the esc to save some weight.
Did you 3D print your motor mount in PLA or PETG?
Nov 19, 2020, 05:16 PM
old4570's Avatar
Adapter plate is PLA ..
PLA is fine as long as you dont melt it .
Nov 19, 2020, 11:59 PM
Andy852's Avatar
Printed some mounts for the 1306.
Nov 20, 2020, 12:56 AM
old4570's Avatar
I was thinking of going that rout ... But there were so many variables to account for .
+ my 1106 mount is so well glued in .
I would only end up doing a awful lot of damage .
+ The adapter plate can come off and the 1106 can go back in , if needed .
Nov 20, 2020, 05:18 AM
Andy852's Avatar
Mine is ready for flight tests tomorrow with a couple of different prop sizes.
I hot glued in the new mount and hard wired the ESC to the motor.
I did not have to modify the cowl so far.
Nov 20, 2020, 05:45 AM
old4570's Avatar
Sounds good !
Hopefully the wind will be down tomorrow ...
Was windy today .
Question Lines on video on micro AIO camera zanek FPV Talk 3 Apr 29, 2020 11:56 PM
Discussion Durafly TUNDRA - ASSEMBLY Video Wisconsin John Electric Plane Talk 0 Mar 05, 2016 09:05 PM
