New MKS HV75K-R and DS75K-R Servos
MKS just released two new models of the 75Ks, dubbed the HV75K-R and the DS75K-R.
Two New Servos from MKS
MKS just released two new models of the 75Ks, dubbed the HV75K-R and the DS75K-R. Now you can get the very popular 75K servo with wing mounting tabs! Check out the full specs below.
MKS-DS75K-R
  • Dead Band: 0.001ms (Default)
  • Control System: +Pulse Width Control
  • Working Frequency: 1500μs / 333hz data: 850μs~2150μs
  • Operating Voltage: 3.7 ~ 6.0 V DC Volts
  • Operating Temperature Range: -10 to + 60 Degree C
  • Operating Speed (4.8V): 0.16 sec/60° degrees at no load
  • Operating Speed (6V): 0.13 sec/60° degrees at no load
  • Stall Torque (4.8V): 1.85 kg.cm (25.69 oz/in)
  • Stall Torque (6V): 2.20 kg.cm (30.55 oz/in)
  • Motor Type: Coreless Motor
  • Potentiometer Drive: Direct Drive
  • Driver Type: FET
  • Bearing Type: 2 Bearing
  • Gear Type: 7075 Chrome-Titanium alloy gear
  • Dimensions: 23 X 9 X 16.7 mm
  • Weight: 7.5 g
MKS-HV75K-R
  • Dead Band 0.001ms (Default)
  • Working Frequency: 1520μs / 333Hz
  • Operating Voltage: 3.7 ~ 8.2 V DC Volts (for 2S ~ 1S LiPo)
  • Operating Speed (7.4V): 0.10 sec/60° degrees at no load
  • Operating Speed (8.4V): 0.09 sec/60° degrees at no load
  • Stall Torque (6V): 2.30 kg/cm (31.9 oz/in)
  • Stall Torque (7.4V): 2.8 Kg/cm (38.88 oz/in)
  • Stall Torque (8.4V): 3.3 Kg/cm (45.83 oz/in)
  • Driver Type: FET
  • Bearing Type: 1x Ball bearing + 1x Oil retaining bearing + x Jewel bearing
  • Weight: 7.5 g
See the MKS-DS75K-R Here
See the MKS-HV75K-R Here
Nov 19, 2020, 11:52 PM
Entropy is happening!
Jim.Thompson's Avatar
Very nice little servos. Great for sailplanes.
I will be looking for a supplier outside the US.
Jim.
Edit:
Found one - https://www.davestoysforbigboys.com....voltage_servos
New Product MKS DS75K Servo RCPC Hand Launch 52 Jun 06, 2017 03:10 AM
Discussion FrSky X4R and MKS DS75K power consumption cgmoth Hand Launch 16 Mar 31, 2016 06:01 PM
Cool New MKS micro digital servo... Troy High Performance 23 May 21, 2011 08:04 PM
Discussion Mks New Standard Servo Size For Your Heli Rudder fuhsong Electric Heli Talk 0 Jun 22, 2009 04:02 AM
