OMPHOBBY T720 RC Plane RTF 6-Axis Gyro Stabilizer
The T720 is a great trainer, FPV platform or just a general go out and have some low stress fun kind of rc airplane.
Lots of fun for just $99
The T720 is a great trainer, FPV platform or just a general go out and have some low stress fun kind of rc airplane. This $99 RTF bird comes with everything you need in the box and even includes a 6 axis flight stabilization system. Check out the full feature and spec list below.
Features:
  • Highly efficient aerodynamic design for great glide performance
  • Concealed servo design makes the aircraft clean and neat
  • Integrated OFS (OMP Flight System), an enhanced electronic flight stabilizer, can be switched between trainer and sport flight modes
  • 4 channel radio included. Dedicated switch for different flight modes
  • High performance SunnySky brushless motor and EOLO propeller
  • Modular parts for easy assembly
  • Frame is made of high strength EPP
Specifications:
  • Wing span: 716mm
  • Length: 528mm
  • Height: 150mm
  • Weight: 130g approximate
  • Brushless Motor: SunnySky 1406 KV2500
  • Propeller: EOLO 5.5 inch
  • Battery: 2S 7.4V 300mAh LiPo
  • Flight controller: Integrated OFS
  • Flight time: approximately 15 minutes
  • Radio range: 200m (600 feet) approximate
Click Here to Visit the OMPHOBBY T720 Airplane Page
Nov 18, 2020, 03:11 AM
old4570's Avatar
Great first plane .
So stable and best of all lands itself - Just cut the throttle and it does it with little to no input .
Just be sure to be reasonably low and aligned with where you want the model to land .
This plane is so stable , even the factory Tx in full stability mode is easy to use . Bind it to a hobby grade Tx and it becomes so easy to fly you could do it half asleep . Dare I say , it's almost boring to fly for exp pilots . Might make for an excellent FPV platform because it's so stable and predictable .
Nov 18, 2020, 10:42 AM
MK
MK
What hobby grade Tx can you bind this too?
Nov 18, 2020, 04:29 PM
old4570's Avatar
You will need a 3rd party micro Rx like you use on a quad . ( Sbus )
This connects to the flight control board and allows you any .
I am using a DSM2 SAT Rx on mine . The S720 uses a S-FHSS Rx
New Product OMPHOBBY T720 4Ch Trainer RC Airplane EPP with Gyro 716mm Wingspan - RTF tymodel Parkflyers 89 Nov 17, 2020 02:23 PM
Mini-Review OMPHobby T720 4-channel gyro-stabilised Trainer RTF 1auriec Parkflyers 59 Aug 17, 2020 03:01 AM
Video OMPHOBBY T720 (SUNNYSKY) 2.4GHz, 4Ch, 6 Axis RC Airplane, Brushless, 716mm, EPP (RTF) hermit81 Parkflyers 0 Mar 24, 2020 05:11 AM
Discussion JJRC JJ - 1000 Headless Mode 6 Axis Gyro 2.4GHz 4CH RC Quadcopter RTF Rx_R Beginner Multirotor Drones 5 Apr 15, 2016 10:53 PM
