This thread is privately moderated by GRW3, who may elect to delete unwanted replies.
Nov 12, 2020, 12:20 AM
Modeling Retread
Doofus Driven Repair
I smacked my GP Zero in while trying to get slower on my landing approach. I was so mentally tied up on my touch and goes that I didnít notice the wind had shifted into my face. Not the the infamous downwind turn, just a plain straightforward stall - into the ground. I broke the cowl loose and shatters the lite ply electric motor mount. Now, Iím putting it back together.
Even though it crashed on a textile runway, some pieces were missing. I decided to cover all four sides with 1/32nd plywood.
The cowl mount ring may not be repairable. I might have to go to a more standard approach.
Nov 12, 2020, 07:45 AM
aircraft general
First, i am a new member to this site and in time will get use to this forum, I am building a Balsa usa 1/3 scale Newport 28 , I am also wondering which covering to use Ie Planetex or Stits . anyone who has experience with ither i would like some input
Thank you
Nov 16, 2020, 08:21 PM
allang46's Avatar
Covering
I would suggest Sig Koverall.
It is as strong as Stits and a lot easier to work with.
It can be bought in a wide range of sizes.
And the best part is that it shrinks with semi low heat very uniformly.
Nov 17, 2020, 07:24 AM
aircraft general
Thanks for the info, i will check it out
Al.
Discussion Mr. Obama Dubbed Doofus By Commentator LcJ Life, The Universe, and Politics 58 Nov 05, 2013 11:59 AM
Question Shaft Driven or Belt Driven 4WD? deathstar Car Talk 5 Dec 04, 2009 06:38 AM
Discussion Motor driven tail rotor spin the same as belt driven tail? BowerR64 Micro Helis 4 Mar 17, 2008 11:53 PM
Doofus zero-zero Slope 10 Nov 25, 2005 03:27 PM
Tail rotors - shaft driven versus seperate tail motor driven prop JohnM Micro Helis 2 Jun 10, 2004 12:15 PM
