The iFlight Crystal HD Antenna is specially designed for the DJI Digital FPV Goggles to replace the stock front plate. It's composed of two carefully designed and highly sensitive LHCP high gain directional antennas that give you better reception at long range as well as better penetration through trees, bandos or other difficult terrain. Replacing the front plate gives it a low profile. It uses high quality RG178 cables for best durability. They were able to achieve a super wide antenna beam width through an offset angle of 30 degrees between the two antennas with a total horizontal beam of 105 degrees and vertical beam of 75 degrees at 9dBi gain, dropping off slowly the further you get to the side! You also get the option to mount your antennas either at the bottom or top pair of the Goggle RP-SMA connectors and they have 3 different color options to choose from. You can pick them up at the link below for $44.99.
Thread Tools |
iFlight Crystal HD Range Test |
Thread Tools | |
Similar Threads | |||||
Discussion | iFlight DC3 HD SucceX Mini-E F4 3 Inch FPV Racing Drone PNP BNF w/ DJI Digital HD FPV | Merch | Banggood.com | 13 | Oct 23, 2020 09:47 AM |
New Product | iFlight 5.8GHz 2dBi High Gain FPV Long Antenna SMA/MMCX/UFL RHCP for FPV RC Drone Air | Merch | Banggood.com | 0 | Sep 20, 2019 08:20 PM |
New Product | iFlight SL5 HD 215mm 5 Inch RC FPV Racing Frame Kit compatible with DJI Digital FPV | Merch | Banggood.com | 0 | Sep 15, 2019 02:32 PM |
New Product | iFlight MegaBee HD SucceX Mini-E F4 3 Inch FPV Racing Drone PNP BNF w/ DJI Digital HD | alex_nikiforov | Banggood.com | 0 | Sep 06, 2019 10:42 PM |
New Product | 160mm Foxeer 5.8GHz 8DBi Echo Patch RHCP FPV Antenna+Foxeer Echo Patch 5.8G 8DBi LHCP | alex_nikiforov | Banggood.com | 0 | May 31, 2019 07:33 AM |
