ARRMA engineers have updated the TYPHON 6S BLX 4WD Speed Buggy with a brushless power system featuring the Spektrum Firma 150A Smart ESC and Firma 2050Kv brushless motor. The combination lets you cut loose with incredible torque, acceleration and speed, while the heavy-duty aluminum and steel chassis and transmission components take it all in its stride. For improved steering, ARRMA® also includes a new, steel gear Spektrum S652 Digital Servo — which is 32% stronger and 5% faster than the previous version's ADS-15M servo.
The ready-to-run package now also includes a 3-channel Spektrum™ SLT3™ radio and Spektrum™ SR315 dual protocol receiver. Perfect for long hours of fatigue-free bashing, the transmitter's ergonomic design features a foam steering wheel for precise fingertip control and an improved hand grip and trigger feel. If you're a new driver, you'll be able to set throttle limits at 50% or 75% until you're ready to use the full speed potential. The SLT3™ is compatible with Tactic SLT™ receivers to run other RTR vehicles you may own, and includes a third channel to control optional features such as lights and winches on models that have them.
Because the SR315 receiver can use SLT and DSMR protocols, you can easily upgrade to a Spektrum DSMR transmitter later — then, download the free Spektrum™ Dashboard™ app for your mobile device and take full advantage of the Smart telemetry capabilities already present in the Firma™ electronics. You'll be able to receive real-time updates of ESC temperature, receiver (BEC) voltage, drive pack voltage and motor RPM.
The TYPHON 6S BLX 4WD Speed Buggy blasts over dirt, asphalt and grass, with adjustable oil-filled shocks soaking up the bumps. The shocks are mounted on black-anodized aluminum towers and include aluminum shock caps and protectors to maintain their super-smooth damping.
For the durability needed to support intense brushless performance, ARRMA® uses a strengthened, anodized aluminum chassis as its foundation. Front and rear composite chassis braces and composite chassis side pods add more toughness. All-metal diff outdrives and gearbox internals, plus durable steel driveshafts, all contribute to a reliable, heavy-duty drivetrain that holds up to extreme bashing. A "never loose" aluminum steering servo saver and "never pop" ball ends supply more precision, reliability and confidence.
ARRMA® holds your maintenance downtime to the minimum with an efficient, driver-friendly design. A sliding mount gives you quick, hassle-free access to the motor. The center diff is easy to reach and can be removed by taking out just four bolts.
ARRMA® TYPHON™ 6S BLX 1/8 Speed Buggy 4WD RTR (1 min 5 sec) |
The low-drag buggy wheels, now with +1mm hexes, arrive outfitted with super-aggressive, multi-surface dBoots® KATAR™ tires. A low-drag wing helps keep the vehicle grounded. Both contribute to confident control and responsive handling at thrilling high speeds. Topping it all off is a sleek buggy body with streamlined good looks, featuring a matte black and red paint scheme with forged composite detail.
Thread Tools |
Thread Tools | |
Similar Threads | |||||
Discussion | ARRMA 1/8 Kraton 6S BLX Brushless 4WD RTR | bill34207 | Electric Power Cars | 58 | Jun 29, 2020 09:25 AM |
New Product | ARRMA Typhon 6s BLX 1/8th 4WD RTR Buggy Thread | lightrules | Off-road Cars | 283 | May 15, 2020 04:25 PM |
News | 1/7 MOJAVE 6S BLX 4WD Desert Racer with Spektrum RTR | Jim T. Graham | Off-road Cars | 1 | Sep 05, 2019 01:03 PM |
Discussion | 1/8 Kraton 6S BLX Brushless 1/8 4WD Speed Monster RTR only | arikair | Vendor Talk | 5 | Jan 08, 2019 08:50 PM |
ARRMA Kraton 6S BLX Brushless 1/8 4WD Speed Monster RTR | arikair | Vendor Talk | 0 | Jan 02, 2019 02:30 PM |
