AJ Aircraft - Spooky Sale!
Here is a great sale for a limited time!!
Halloween Sale
AJ Aircraft is having a sale this weekend only!
The 104" ARS 300 is $999.99
This spooky discount ends soon!
  • Wing Span - 104"
  • Length - 102"
  • Height -
  • Wing Area -
  • AUW (dry) - 26-28 lbs.
  • Gas Power - 100cc to 120cc
  • Radio - 9 channel with 8 high torque servos (400 oz./in minimum) & 1 throttle servo
  • IMAC Legal!
AJ Aircraft 120cc ARS 300 Wednesday Noon Time Demo (4 min 27 sec)
Recommended CG Range and Control Throws
  • The center of gravity (CG) range for the 104" ARS 300 is located 1-1/2" in front of the wing tube (+/- 1/2")
  • Aileron Control Throws
  • Low Rates - 15 deg. (30% Exp)
  • Mid Rates - 35 deg. (40% Exp)
  • High Rates - 45 deg. (50% Exp)
  • Elevator Control Throws
  • Rudder Control Throws
  • High Rates - Max Throw (50% Exp)
What's in the box:
  • Pre-hinged, glued and sealed ailerons & elevators
  • High-quality embroidered cloth wing bags & stab bags
  • 5" carbon fiber spinner pre-cut for two blade prop
  • Carbon fiber main landing gear
  • Carbon fiber main wing tube
  • Dual carbon fiber stab tubes
  • Removable horizontal stabs & rudder
  • G10 fiberglass control horns
  • Aluminum reinforced landing gear mount
  • Aluminum reinforced firewall
  • Aluminum standoffs for gas engines
  • Full-length canister tunnel
  • Canister muffler mounts
  • Heavy duty foam wheels with aluminum hubs
  • Heavy duty steel axles
  • Heavy duty pre-drilled wheel pants
  • Pre-drilled & rubber lined landing gear cuffs
  • Firewall drilling templates for common engines
  • Pre-run rudder pull-pull wires
  • High quality ball links & turnbuckles for all connections
  • Extra hardware bag for spares
  • Velcro for fuel tank or battery restraint
  • All airframe components covered in genuine Ultracote, available in 2 color schemes
  • Origin Scheme (White HANU870, Orange HANU877, Midnight Blue HANU885, Silver HANU881)
  • Fusion Scheme (White HANU870, Pearl Purple HANU847, Fluor Lime HANU893, Pearl Charcoal HANU846, Silver HANU881)
  • NOTE: This product is shipped in two separate boxes.
  • The main box measures 97"L x 20"W x 22"H (59 lbs. total), The wing box measures 53"L x 30"W x 9"H (23 lbs. total).
Learn More
Head over to AJ's store for all the info!
Discussion AJ Aircraft 60" AJ Laser 230z Scottyb313 3D Flying 316 Aug 19, 2020 07:05 PM
Article AJ Aircraft - Spirit of Joe Nall Sale!! Jim T. Graham 3D Flying 4 May 16, 2020 01:23 PM
Discussion AJ Aircraft 60" AJ Laser 230z AJ_Aircraft 3D Flying 4 Feb 01, 2016 12:42 PM
Discussion AJ Aircraft 105" AJ Laser 230z Scottyb313 3D Flying 22 Dec 31, 2015 08:37 AM
Article 5 Spooky R/C Aircraft for Halloween Jason Cole Electric Plane Talk 20 Oct 28, 2015 01:56 PM
