Oct 29, 2020, 04:12 PM
hager's Avatar
My new DIY winch and retriever
I have wanted a winch for a long time but most of the people I know who have winches generally do not use them because of the effort to carry and setup for short sessions. High-starts are ok but the enthusiasm wears off quickly with retrieving and crosswinds. I have electric powered sailplanes but there is something special about DLG's and winch/highstart sailplanes. I enjoy the pure and simple aspects of a non electric sailplane. I am not a competition flyer and primarily fly woodies in the 2M and under range so the traditional Ford starter motor winch is both overkill and cumbersome. So here is a quick preview of what I have come up with. Preliminary calculations and testing shows that it is quite capable of launching small Park Flyers and larger sailplanes so I will post additional photos and videos if there is any interest.
My design considerations
- Ability to launch Woodies and smaller gliders with out folding wings for beginners.
- Should be quick to setup like a high-start.
- Easy to operate so I would be inclined to use it when my time is limited.
It is based on a 24V electric scooter motor and two 12V 9A batteries in series to provide 24 volts. The winch weighs 15lbs and the retriever 32lbs including the batteries.
- Winch - 24V 300 Watt MY1016 motor
- Retriever - 24V 100 Watt MY6812 motor
- 30A speed controller
The inspiration came from Allen Moore (YouTube) and mdennis (RCGroups).
Allen Moore - DIY RC Glider winch
https://www.youtube.com/channel/UCxp...5hanSysA4vodQA
mdennis - $250 Winch Line Retriever with Automatic Pickup
https://www.rcgroups.com/forums/show...tomatic-Pickup
Oct 29, 2020, 08:16 PM
Very interesting. Where did you get the winch spool?
Oct 30, 2020, 12:01 PM
Brinsomr
Beautiful workmanship!!
Oct 30, 2020, 05:22 PM
hager's Avatar
The spool was made in three pieces plus the mounting hub for the motor. I have listed the parts below. The v-groove for the spool belt break was created by using an aluminum alternator pulley. My small lathe would not allow me to turn one so I improvised. It is very solid and has no twist or movement what so ever. Sorry no pictures of it unassembled.
Summit Racing Deep Groove Aluminum Alternator Pulley
McMaster Carr Multipurpose 6061 Aluminum Round Tube, 1/8" Wall Thickness, 3" OD, 6" Length
McMaster Carr Multipurpose 6061 Aluminum Sheet, 0.19" Thick, 6" x 6"
McMaster Carr Multipurpose 6061 Aluminum, 2" Diameter, 1/2" Length
McMaster Carr Black-Oxide Alloy Steel Socket Head Screw, M6 x 1 mm Thread, 180 mm Long
Oct 30, 2020, 05:58 PM
Duane, LSF IV
Wazmo's Avatar
Part links
https://www.summitracing.com/parts/sum-g3969
https://www.mcmaster.com/9056K41
https://www.mcmaster.com/89015K275
https://www.mcmaster.com/1610T15
https://www.mcmaster.com/91290A114
HTH
Nov 09, 2020, 12:00 PM
hager's Avatar
Field Testing
Well I have done some initial testing and field trials. The winch needed nothing and worked flawlessly. We were able to launch a Gently Lady and an Aegea Mantis. No big zoom with the Mantis launch but that is not the purpose for the winch. I could not be more pleased with the ease of setup and performance. The batteries did not discharge at all so there is no concern about the power being shared for both the winch and retriever. The variable speed works well for different models and also for winding the line up at the end of the day. The retriever needs some tweaking but is close to being finished.
Being that the retriever is a direct drive motor there is not enough friction in the system to allow for the magnetic bail to stay in position for launching and release. I will be adding a pull solenoid to release the bail. It also will simplify the retriever reset as it is spring loaded and will automatically lock into position when the bail is raised. Pics to follow once assembled.
Mods:
- One way bearing to prevent backlash.
- Adding a solenoid for the bail release.
Updates to follow...
Nov 18, 2020, 10:26 PM
hager's Avatar
Updates are now complete
Its been a long project and I am waiting hoping for some warmer weather to finally get out and use it. Bench testing is complete and now its time to fly! I have a Willy Nillies Gentle Lady 250 48.5" and a J&H Aerospace Micro Bird of Time 48" on the bench being finished and being able to use the speed control to adjust the spool speed will be great. One winch for all of the various sailplanes.
The updates I have added are:
- A one way bearing to prevent line backlash.
- A solenoid for one handed bail operation.
- A switch to isolate the speed control and run direct from the 24V battery.
This was done so that there are no power losses from the speed controller when launching larger sailplanes.
Components
CSK8 One way Bearing Sprag Freewheel Backstop Clutch - VXB Bearings . com
Guardian A420-065924-00, 24V Continuous Duty Pull Solenoid - Onlinecomponents . com
Guardian A490-367461-02, Spring Kit - Onlinecomponents . com
Another shout out to Allen Moore (YouTube) and mdennis (RCGroups) for the inspiration, Thank you.
Video of Solenoid Test:
RC Sailplane Winch Line Retriever Solenoid Test (0 min 11 sec)
Dec 13, 2020, 11:32 AM
hager's Avatar
Updates and a day at the field
I have changed the retriever motor to a 200W motor to overcome drag from my bicycle hub turnaround and line laying on the grass. The original 100W worked provided you were using an elevated and large diameter turnaround pulley like a F3B/F3J style. I will work on a new turnaround over the winter. I also replaced the extra hand switch a with a foot switch. I find the hands-free more practical and if I'm flying with others they can retrieve and set the winch and retriever up for the next pilot.
We have fourteen inches of snow in the forecast so I'm glad it is complete now that I will likely be waiting until next season...
- Unite Motors MY1016 - 24V, 200W, 11.2A, 2600RPM
Retriever Operation Video
RC Sailplane winch / Retriever Operation (3 min 19 sec)
Dec 13, 2020, 11:40 AM
whacker's Avatar
Good for you Hager, and thanks for the Posts and Great pics
Goes to show, it is possible from scratch, and there is a chance yet others may stick to the hooks under the fuse.
whacker
Dec 13, 2020, 09:17 PM
Going in circles.
GliderJim's Avatar
Really nice setup that is a lot less scary for woody pilots to use. Full pedal launch without fear.
Discussion Winch Retriever Hoops (Line Guide) hager Sailplane Talk 11 Sep 30, 2020 08:11 AM
Discussion Winch retrieval woogie_man Sailplane Talk 6 Apr 26, 2019 09:04 PM
Build Log My New Retrieve Boat RayR Racing Boats - Electric 4 Mar 20, 2017 03:23 PM
Discussion Winch and Retriever at Sheldon's Don McCullough South Bay Soaring Society 0 May 13, 2016 01:40 PM
