Recovering an airplane
I was lucky enough to be given a Carl Goldberg Anniversary Edition Piper Cub from a guy in the local club. It hasn't been flown in several years, has some minor damage in a few places, and generally needs a lot of work to get it looking nice again. I've decided to recover it in olive drab green. Not having much experience with covering, my question is: Is it better to remove the ailerons, rudder, and elevator to do this, or can I do an adequate job of covering the airplane without removing these parts?
TIA, Mike D. |
Yes, you can cover without removing the moving bits, but that makes it a little more difficult to get the old covering off, as well as putting the new one on, as the others have said. It also leaves edges which can come loose more easily because you aren't able to wrap them around to overlap.
But if you decide to go that route, after you've finished re-covering you can go over the exposed edges, and any bits of the old covering that are still showing through in the cracks, with olive drab paint using a small brush. That'll tidy it up, and help seal the edges of the covering. |
You can slice through the hinges to remove the control surfaces and then re-hinge in a different spot right next to the old hinges.
Latest blog entry: Another plane for the hangar: Piper...
I would (and did) recover a J-3 which was cub yellow without removing hinges. And did use touch-up olive drab paint for the problem areas. As for the loose edges that wouldn't adhere I went over edges with a bit of CA. The extra time spent covering will be well worth the extra effort. Oh and by the way it's not a J-3 anymore but with invasion stripes it's an L-4 Grasshopper
Piper L-4 Grasshopper![]() ![]() |
Thread Tools | |
Similar Threads | |||||
How does an airplane fly inverted? | smithrl | Power Systems | 50 | Jun 26, 2008 03:38 PM | |
Questions On The Lift Of An Airplane | putt_13 | Modeling Science | 9 | Aug 14, 2002 03:15 PM | |
Best method to pack/protect an airplane to be shipped via USPS or UPS. | Scott C | Electric Plane Talk | 19 | Dec 03, 2001 05:04 PM | |
Here is how you cover an airplane | squelchF18 | Beginner Training Area (Aircraft-Electric) | 1 | Nov 13, 2001 08:40 PM | |
How can I waterproof an airplane? | Lanceh007 | Power Systems | 1 | Oct 21, 2001 10:38 PM |
