This week on What the Heck Wednesday we have a nice looking DC3 twin electric scale model. The crash footage starts at about the 6:25 mark in the video below. The plane rolls down the runway and takes off immediately into a hard right hand barrel roll. It only gets half a roll in though because, well the ground. It lands hard nose first and inverted. The nose is pretty much toast, but being a wooden airplane, it's totally repairable with some time and effort. So what happened? The pilot said it was windy, but I'm not sure wind was the issue on this one. Let us know your thoughts in the comments below and tell us what you think went wrong.
If you have a video of a weird or entertaining crash and would like to be featured on What the Heck Wednesday, please send me a PM with your submission.
- BIG CRASH - The Last flight of my DC3 - RC Airplane (7 min 40 sec) |
Thread Tools |
Dang, thats an unfortunate crash. It honestly looks like a gust came in a caught the plane as he was taking off. Given how well the first flight went, unless a servo failed between flights, I have no idea what happened.
On a separate note, can we all take a moment for the fly that got caught up in the left prop and bounced around under the plane at 6:42? RIP Fly. Actually, I think that fly is to blame. It hit the left prop and bounced off the underside of the plane. Maybe that was no ordinary fly. It was a SUPER FLY! The force of him hitting the prop threw it out of balance, then the subsequent hit to the underside picked the plane up in the wrong way causing the wind to catch it and throw the plane. Case closed. |
LOL on the fly!
Classic DC-3 stall. A ton of people have lost their HobbyKing DC-3s to that exact same stall. Plane left the ground too early, pitched up, stalled and in she went.
Look up people maidening the HobbyKing DC-3 and you will see this same crash a lot.
Simply an early rotation, the plane started flying with nearly a critical angle of attack, one wing got more loaded up than the other as he continued to apply back pressure and the right wing stalled more than the left (hence the roll/low to the ground spin entry). Always unload the wings (relieve back pressure and increase forward pressure if you aren't too low already to do so) at the sign of an incipient spin or accelerated stall.
The model does an awful lot of jigs and jogs while in the air. Some of it appears to be the turbulence but some of it seems to be very set up to be very sensitive on the controls. That might have been a contributing factor.
Looking at the portion with the power up and takeoff that led to the crash. First off when the grass held back the gear and the tail initially lifted it slewed strongly to the right. That suggest one of two things. Either the right side motor is pulling much more strongly or there was a fairly strong cross wind from the left quarter. Given that it rolled strongly to the right I'm voting for trying to take off into a strong cross wind. Earlier in the video the wind sock appeared to be right down the runway. But we've all seen where the direction can change quite a bit for a few seconds at a time then return to the more usual direction. He may have gotten one of those and didn't recognize it for what it was. Or it may have been just a momentary sudden direction shift. But given the way the model "hinged" in yaw when the tail first came up before the roll started I'm thinking that it was a longer shift which he should have recognized and dealt with by swinging into the wind more directly before applying takeoff power. |
Look the original video and you can see FULL elevator during takeoff run ..... |
If you abuse it you get this.
Some footage of stalls in the full-scale aircraft.
https://youtu.be/2tvsKLuEar4
Bummer of a way to learn that lesson. Andy |
On our grass field, my scale or warbird taildraggers won't taxi without nosing over if I don't use full up elevator. So it's okay to start the rollout with full up elevator but then it should be neutralized before liftoff. And in a crosswind, same with the ailerons. Turned into the wind for rollout but then gradually back to neutral as the plane lifts off.
Looks to me like it was not a dead cross wind, but it was slightly quartering from behind making it a slightly downwind takeoff - in addition to what's been said above. Check the geometry on the grass lines vs. wind sock starting at about 6:10
Use full up elevator only for the initial pull away on grass, when the plane starts to roll let the elevator back to neutral over a couple of seconds to allow the tail to gently rise then apply power to take-off speed, preferably not across wind as this one was. Maybe even more speed might not have saved this one.
Thread Tools | |
Similar Threads | |||||
Article | What the Heck Wednesday - RC Gas Trainer Crash | Jason Cole | Fuel Plane Talk | 57 | Dec 13, 2020 06:34 PM |
Article | What the Heck Wednesday - Nose Falls Off on Landing | Jason Cole | Electric Plane Talk | 43 | Oct 20, 2020 09:04 AM |
Article | What the Heck Wednesday - RC Warbird Crash | Jason Cole | Electric Warbirds | 12 | Oct 08, 2020 08:09 PM |
Article | What the Heck Wednesday - RC Helicopter Crash | Jason Cole | Electric Heli Talk | 26 | Sep 15, 2020 09:43 AM |
Article | What the Heck Wednesday - RC Jet Crash | Jason Cole | Fuel Jet Talk | 31 | Sep 13, 2020 06:26 PM |
