Oct 27, 2020, 06:47 PM
Bob
Total Newbie, BLADE INSTALLATION
Im almost embarrassed to ask this question but I’ll never know for sure so here it goes. I just finished my first build a SAB FIREBALL. I need to know if i got my blades on correctly so ill try to explain it in the simplest way i can. Standing directly behind the heli the main rotor blades spin clockwise and to the right correct?
Second the tail rotor blades spin backwards toward me if im standing directly behind the heli correct?
And finally to make sure i have my main rotor blades and tail rotor blades installed correctly , the leading edge ( thickest part of the blade) should be first going into the direction the blades are spinning correct??
I really appreciate you guys and the willingness to help newcomers like myself through these growing pains.
Oct 27, 2020, 11:40 PM
Yes to all your questions
Oct 28, 2020, 06:35 AM
Bob
Thanks Suckerpunch, I really appreciate the help😀
Oct 28, 2020, 03:37 PM
Psycho_DaD's Avatar
as mentioned by Suckerpunch, it's 3 time a 'yes' on all your questions.
Regarding spinning direction of main blades and tail blades you could also check your manual page 14
https://www.manualslib.com/manual/13...page=14#manual
main motor spins clock wise from left to right + tail blades spin backwards
ps: that's quite a bee on steroids you have there
Oct 29, 2020, 11:40 AM
Helique's Avatar
“Total Newbie” “first build” and “SAB FIREBALL”
Btc624: what experience do you have flying RC helicopters?
Oct 30, 2020, 06:52 AM
Bob
Just a S2 nano and alot of Sim time, I really wanted to build a kit so when i do crash i’ll have a good idea of how it all goes together, still I’m gonna use training gear for starters.
Oct 30, 2020, 08:03 AM
Tarot 550/600 & OMPHobby UK
Smoggie's Avatar
On a belt trive heli like the Fireball always double check that the tail rotor does spin the correct way (the front tail blade should rise). It's very easy to get the twist of the belt wrong and end up with a reverse tail direction.
The pitch control arms on the grips (main and tail) must be on the leading side of the grip (facing direction of rotation).. Getting the grips reversed is another easy mistake.
Finally before flight it's a really good idea if at all possible to get an experienced heli flyer to give the heli a quick check-over. Helis are unforgiving beasts and it just takes a small mistake in build or setup to cause the maiden flight to end badly.
Question Continuous Beep in Mission Planner (Total newbie here) EwenB Beginner Multirotor Drones 10 Jun 26, 2016 02:32 AM
Discussion Total and Complete Newbie PilotWerx FPV Equipment 1 May 19, 2016 10:58 AM
Discussion Total newbie dx6 question Thermal surfer Radios 6 Apr 18, 2016 12:32 PM
Help! Total Newbie Question williamjmmorgen FPV Equipment 2 Jan 22, 2016 05:27 AM
Discussion TOTAL newbies review of a Blade CX Bigfoot21075 Coaxial Helicopters 14 Dec 29, 2008 05:43 PM
