Oct 27, 2020, 07:42 AM
ISDT P10 Charger discussion
ISDT has released the value line dual charger model P10. There is not much information about it and almost zero reviews so far. Lets discuss about this charger in this thread.
Also I'm going to get one and test/review it.
Available @
Banggood: http://bit.ly/Banggood-ISDT-P10-Dual...-Smart-Charger
Features:
(spelling and grammar were not corrected )
1.High Power Synchronous Dual Channel, with Smart Charging.
Smart High Speed Processor delivers parameter interfere to each port.
Hassle Free with Maximum charging power up to 250W for single port.
2.Synchronous Parallel charging.
Built-in High Speed Processor Synchronous Balance two channel charging.
Maximum Parallel Charging power up to 400W.
P10 deliver charging current range from 10A ~ 16A.
3.Support USB interface to upgrade firmware
Connecting the computer through the USB-C interface, upgrade to the latest firmware
Always maintain the advanced performance and features.
4.Adjustable Digital Power Supply
The CH1 of the charger can become a DC power supply.
In adjustable digital power supply mode, the Max. power is 120W.
CC: 0.2~5A
CV: 5~24V
5.Lights off in the dark
introducing the dark mode.
scOS 2.0 new dark mode feature,
Suitable for low light scenario,
System will adjust the interface in dark tone,
Reduce light damage to userís eyes.
While remaining the iconic and comfortable charging display style.
Specification:
Model: ISDT P10
Input voltage: DC 10~30V
Output voltage: DC 1~26.4V
Max. input current: 20A
Charging current: 0.2~10.0A*2
Balance current: 0.5A/Cell Max
Max. charging power: 250W*2
Abnormal voltage alarm: Support
Incorrect cell count setting alarm: Support
Supported Quick-charge: LiFe, LiIon, LiPo, LiHv 1-6S,
Pb 1-10S; NiMH, Cd 1-16S
Working temperature: 0~40℃
Storage temperature: -20℃~60℃
Dimension: 90.5◊90.5x47mm
Weight: About 250g
Reserved for more info.
Oct 27, 2020, 01:37 PM
Max charging current of
10.0A*2
must mean via two ports?
since "parallel maximum" is listed as 16A?
I want to know, for 1S per-cell maximum
that would mean ~40W each x2 cells
or ~64W for a single cell, both ports in parallel?
Oct 28, 2020, 03:02 PM
10.0A*2
Yes, the maximum Amp output is 16A via parallel connected outputs or 10A per single output.
Yes, your math is correct. But does it really provide 40W through the two separate outputs simultaneously (80W total) - that is a question. What are you trying to charge? A lot of1S batteries in parallel?
Oct 28, 2020, 03:37 PM
single units of larger Ah capacity, cap testing, manual balancing
Oct 29, 2020, 03:12 PM
model aviation is not a crime
justplainold's Avatar
Works great, its BattGO so it reads the chip data and charges my spektrum smart batteries
Oct 30, 2020, 04:55 AM
Interesting. The product description does not mention the BattGO feature. Good to know.
Oct 30, 2020, 10:06 AM
Group44's Avatar
I am curious to know how it can read the Spektrum Smart battery chip, it doesn't appear to have the connection for the data wire on the Spektrum Smart battery.
Oct 30, 2020, 02:36 PM
I made the Amass XT60i-F battery side to IC3 device side adapter
It's in my blog
Oct 30, 2020, 02:39 PM
Yes, there could be something going on with the spektrum rebranding / licensing of iSDT BattGO technology
Nov 02, 2020, 09:06 AM
Group44's Avatar
I read your blog, what was your source for the Amass XT60i-F connectors?
It's in my blog
Nov 02, 2020, 11:02 AM
Very good, right
one Amass XT60i-F connector came with my new in box 30amp Spektrum power supply, on the device power lead.
I found a US seller on ebay and bought more, that seller seems to have sold out
New Product New chargers from isdt // D1 P10 P20 BG-Wilson Batteries and Chargers 1 Oct 15, 2020 09:10 PM
New Product iSDT SC-608 150W 8A & SC-620 500W 20A & Q6 Plus 300W 14A Balance Chargers czajunia Batteries and Chargers 1757 May 11, 2020 08:36 AM
New Product iSDT T8 & Cube4, Q6 Light, Q6 Pro, T6 Light, T6 Pro - Next Gen iSDT Chargers D Gains Batteries and Chargers 35 Feb 28, 2019 11:45 AM
New Product iSDT SC-620 500W 20A MINI Smart LCD Battery Balance Charger SeByDocKy Batteries and Chargers 0 Jun 12, 2016 06:27 AM
