Oct 26, 2020, 10:00 PM
160a 14s
Hi All,
What are you using for these numbers? Has anyone had experience with Hobby Wing or Scorpion?
https://www.scorpionsystem.com/catal.../14s_160a_esc/
https://www.hobbywingdirect.com/coll...nt=31794182865
Anything else is running 100.00 more and up.
Oct 28, 2020, 10:57 PM
Lee Liddle
Knife Liddle's Avatar
Ive been running several Hobbywing 130a and 160a. Both work great.
Only problem is the instructions are wrong. There are two servo type leads. The one with three wires is for programming. The one with only 2 wires (white and black) is the one that goes to the rx. Very frustrating. Finally googled it and found a thread where the guy had figured it out. Plugged in the correct lead and presto, it worked great. I also recommend the programming box. Worth the money.
Oct 29, 2020, 12:52 AM
Thanks for the hit Knife Liddle! Been trying to get the HW but everyone seems to be sold out. There's only one place I see that has it but it wouldn't get here late Nov to late Dec.
Thanks for the heads up on the instructions. Probably saved me a headache.
I plan on the programming box as I will have to change the numbers for the upgrade I'm looking at.
Oct 29, 2020, 05:15 AM
2020 EDF Jet Jam
Robert Belluomini's Avatar
YGE 205 from Amain hobbies
Oct 29, 2020, 12:35 PM
Nice unit. I see your pay scale for toys is better than mine.
Oct 29, 2020, 05:15 PM
Hobby King has the YEP 180hv. ~$250
Oct 29, 2020, 06:59 PM
That's precisely my second choice since I couldn't get much response on the Scorpion. If I can find the HW, it's 80.00 cheaper but if not, the YEP looks good.
Oct 29, 2020, 07:14 PM
Battery Puffer
Neu sells a APD 200 14s for $200. That's what is in my L-39 I just started building.
Oct 29, 2020, 09:32 PM
Lee Liddle
I have had many yep hv over the years. The early oned seemed to hold up well, but those I've bought in the last 3 or 4 years did not seem to last long. Most of them just stopped arming. So I've switched to the HW Funfly series now. So far so good.
Right now for SHV up to 22s I'm using the Flier Models 22s 400a. Its a beast.Aboutv$240 shipped I think.
That's a pretty good price on the APD from Neu.
There is a series called Vgood that appear to be the same as the APD. Probably a knock off. I'm using several of their 8s 120a and 6s 150a. They work well and are good bargains, but the Vgood series only goes to the 8sc120a. If they start producing the 14s or 20s types I'll have to try them.
Oct 29, 2020, 11:18 PM
A friend was telling me about those earlier. Everything looks good with specs and price. I think the price is competitive because it's pretty bare bones and you have to solder your own wiring, provide protective covering and figure a cooling system/heat sink. Everything else looks great.
Oct 29, 2020, 11:23 PM
Ended up going with the HW. That's actually what came with this jet purchase but when I upgrade to the 14S, I'm going to need this new ESC because the stock one is a 12S and isn't programmable.
Oct 31, 2020, 06:29 AM
There is a thread somewhere that shows how to unlock the stock hobby wing esc that comes with the HSD jets. Not sure if it works never tried myself.
Oct 31, 2020, 12:22 PM
If I stayed 12S, that's worth looking into. Good to know. Going 14S soon though.
Oct 31, 2020, 06:32 PM
Battery Puffer
As long as you have a little airflow over the esc I don't think you need to add anything to the APD. Mine will do 12 -14s and sits in front of the fan with nothing added except some shrink wrap.
I'm pulling 120 to 140 amps which is fine for this esc which can do 200 continuous and 300 burst.
Oct 31, 2020, 08:16 PM
I was so tempted to put it in the airflow duct but I need that to be clean. Thinking about a small, light fan on top.
Those are some good numbers on amps!
New Product Beta Testing the Turnigy dulx 160a HV Knife Liddle Electric Ducted Fan Jet Talk 12 May 04, 2017 10:24 PM
Discussion Buffer pack with Graupner 160a esc hv nanmadpad Graupner Control Hobbies 0 Jan 25, 2016 09:06 AM
Discussion Graupner 160a esc nanmadpad Graupner Control Hobbies 9 Oct 27, 2015 11:46 AM
Discussion Turnigy dlux 160A HV Brushless Speed Controller (OPTO) CoolerByTheLake Power Systems 7 Dec 29, 2011 12:54 AM
Discussion Turnigy dlux 160A HV Brushless Speed Controller (OPTO) callum22 High Performance 1 Nov 17, 2011 11:31 PM
