This thread is privately moderated by Tudball, who may elect to delete unwanted replies.
Oct 25, 2020, 01:17 PM
Trader Rating: 40
Wanted
CNC Router Service
WANTED:: CNC RouterService. Iím in the process of building a heavy lift drone. The motors Iíll be using are KDE 7215 swinging a 28Ē-30Ē props. I have everything I need except the center plates. I have the 3mm carbon sheets and the arm mounts. Iíll accept an off the shelf design for the center plates. I will need a 6Ē solid (blank) cross strip on the bottom plate to a accommodate the retractable landing and to accommodate the power distribution board. I can drill the holes to mount PDB and landing gear. The carbon fiber sheets are 300mm x 400mm. I want the finished plates 300mm x 300mm square. The corners will be set back to accommodate the arm mounts. I will furnish the carbon fiber sheets and one or more of the arms mounts. A rough estimate of the cost will be appreciated.
If you are interested you may contact me at: dickerson13 @gmail.com
Iíll furnish my phone number if you are interest in providing this service. I ask that you furnish your number.
Grover Dickerson
PS: I have 4mm sheets if you think they are needed.
Oct 30, 2020, 01:03 AM
Trader Rating: 1296
Master of the figure 9
punkindrublik's Avatar
PM sent.
Wanted CNC Router Service Tudball Aircraft - Electric - Multirotor AP Drones (FS/W) 1 Oct 03, 2018 10:55 AM
Discussion CNC router service shawnrw CAD/CAM 3 Feb 03, 2014 12:14 PM
Discussion Looking for CNC router services Fossil1977 The Builders Workshop 0 Nov 14, 2009 09:00 PM
Help! CAD and CNC router Services in same house Fossil1977 The Builders Workshop 4 Aug 04, 2009 10:36 AM
