This thread is privately moderated by Doom 3D, who may elect to delete unwanted replies.
Oct 25, 2020, 09:08 AM
New Kolibri Version 10 ECU and updated version of T35 turbine
The changes they made
Starting with the new ecu......
- GSU connects via a servo cable, no longer the large dateline cable used on all the dinosaur systems.
- Smaller, lighter, much more processing power.
- Due to more processing power, lower idle RPM, faster accel/decel is capable due to higher RPM accuracy.
- Single cable from ECU to engine (seperate valve and pump cables).
- More adjustable parameters including preset accel/decel curves all custom to every engine built for maximum performance.
Now the engine........
- Starting with a brand new Billet CNC compressor adding more power and efficiency. Thrust=3.8kg! With a weight penalty of <5grams.
- Single cable braided into a special connector used for the new ECU.
- Redesigned combustion chamber, exhaust/thrust nozzle, center cone, stronger welds.
- Micro JST added to starter motor wires from factory to aid in removing and installing fod screen.
Discussion Kolibri T35 Autostart machone Jet Turbines 12 Nov 30, 2019 04:41 AM
Question Manual for Lambert T35 Kolibri MicroTurbine Autostart velyter Fuel Jet Talk 1 Jan 25, 2017 01:30 AM
Discussion Kolibri T35 powered CARF Spark Haruki Jet Turbines 1 Jul 24, 2015 02:20 PM
Discussion Looking fir Kolibri T35 manual jagdpantherx Fuel Jet Talk 0 Jun 18, 2015 05:36 AM
Discussion Adjusting the T35 kolibri Engine acceleration viperviper Jet Turbines 12 Nov 11, 2014 12:45 AM
