Oct 12, 2021, 03:06 PM
smackfpv's Avatar
Flight with Notamed and co.
Mountain Ridge (5 min 9 sec)
Oct 13, 2021, 12:12 AM
INAV
Olivier_C's Avatar
Originally Posted by smackfpv
Sweet place !
The first tree almost claimed the plane for its own personal use
Oct 13, 2021, 01:04 AM
smackfpv's Avatar
Originally Posted by Olivier_C
Sweet place !
It was very close!
Needed to prop up with the increased launch altitude.
Nosed it in later on but easily repairable thank goodness!
Oct 13, 2021, 09:59 AM
Andy0679's Avatar
Question. The guide for the esc says no cap needed unless running 6S. I have no plans to go to 6S so I left it off. Now some are adamant a cap must always be installed on an esc. Thing is I don't plan to run 6S, and the FC has caps and so on already. What are your thoughts guys?
Tekko 32 65a
Matek F405-wse
T-motor F80
Tattu 4S R-Line 1550
6x4 2 blade folding prop.
Oct 13, 2021, 11:40 AM
Tekko 32 65a
Matek F405-wse
T-motor F80
Same rules as condoms If you wanna keep it clean cap it, it may not work 100% but it will definitely help.
Oct 13, 2021, 06:26 PM
Tekko 32 65a
Matek F405-wse
T-motor F80
You don't have to install it on the ESC if room is tight. I put one on the FC pads adjacent to the ESC/Batt wires.
Oct 14, 2021, 12:42 PM
Andy0679's Avatar
OK Thanks ZaksterBlue. I'll do that. There's no room in the esc compartment unless I hog it out a bit. I wonder if I did run a 6s, would a 5" prop work and would I even see any difference in speed?
Oct 15, 2021, 08:52 PM
Josh Fisk
My 65a was rebooting with a f80 above 60% throttle without a call
Oct 15, 2021, 09:54 PM
Andy0679's Avatar
You mean cap? Was that on 6s? What prop? Battery?
Oct 18, 2021, 05:21 AM
Getting my cruise on...
Lake Burley Griffin - Part 1 (AtomRC Dolphin) (4 min 22 sec)
Oct 18, 2021, 08:14 AM
Originally Posted by trevellyan
r2, is that you?
Oct 18, 2021, 08:17 PM
CrosswindJones
Originally Posted by otdl
Wow dude. wow. Great engineering work on that. I only got time for a PAN at the moment but got an astromech in there at least.
Here's my parts: https://www.thingiverse.com/thing:5024617 and link to OnShape designs.
02 picture
Oct 19, 2021, 04:53 AM
02 picture
DJI cam cable really too short, cause a lot of problems
Oct 19, 2021, 03:19 PM
Finally maiden mines today. Super windy but on stock PIDS and no tuning auto launch on INav was flawless. I chucked it in the air with a side throw with both hands. Rates were a bit slow but auto tune will fix that. Second flight was brief and ended in a nose in crash. I kept getting a failsafe due to rx loss. Need to trouble shoot that. Anyone have an stl file for the battery tray?
Oct 19, 2021, 03:26 PM
Here it is a DXF. You can import this into most CAD software and then just extrude it as high as you want.
New Product Sonicmodell AR Wing Pro 1000mm Wingspan EPP FPV Flying Wing RC Airplane KIT/PNP - KIT scousethief Flying Wings 4 Oct 21, 2020 06:38 AM
Discussion Great Simple, Fast, Cheap, Chuck-in-your-Car Park Flier - Wing Wing Z-84... Herrsavage Flying Wings 11 May 30, 2019 10:41 AM
Discussion Wing Wing Z-84 845mm Flying Wing--Seeking Reviewer BG Tobey Flying Wings 12 Oct 17, 2016 01:53 AM
Discussion Cheap Fast Wing under 30" mt_100 Flying Wings 12 Feb 08, 2016 11:04 PM
