Oct 20, 2020, 09:11 AM
Racer.Lt Owner
Frimen's Avatar
New Product
Skyzone/AtomRC - Dolphine 845mm FPV Wing KIT | PNP | FPV - Fastes cheap wing?
Not much information, but still atleast some
KIT: 99$
PNP: 129$
FPV: 163$
Available for preorders on https://www.banggood.com/ATOMRC-FIXED-WING-Dolphin-p-1758430.html?p=!X1417487447201403QO - referal link
Dolphin FPV flying wing : Day 4 (9 min 1 sec)
Features:
EPP molded wing,embedded with carbon fiber tube, durable and light weight.
Carbon fiber tube enhanced elevens, more rigid elevens during high speed fight.
Detachable wing, portable to transport.
Detachable head, two head for choice, use can choose fly with gopro or without gopro.
Rubber band and magnet to lock the gopro, easy to install the gopro.
V tail design make the wing more stable than normal fly wing.
Pre installed wing and fuselage protector, more durable during landing.
Compatible with GOPRO hero 5~7.
Movable battery slot for better “CG” adjustment.
Pre installed camera cable and antenna for FPV gear.
Air inlet and outlet for FPV gear cooling.
SKYZONE/ATOMRC Wing Dolphin FPV RC Plane (1 min 29 sec)
Dolphine Kit
Wingspan: 845mm(33.2")
Length: 710mm(28")
Motor: 2306 (required)
ESC: 30A with 5V/3A BEC (required)
Servo: 2pcs 9g servo (required)
Propeller recommend: 5~6 inch (required)
Battery recommend : 4S 1300-2200mah (required)
Dolphine PNP
Length: 710mm(28")
Motor: 2306 (included)
ESC: 30A with 5V/3A BEC (included)
Servo: 2pcs 9g servo (included)
Propeller recommend: 5~6 inch (included)
Dolphone FPV Ready
Length: 710mm(28")
Foxeer Razor Nano 1200TVL (included)
AtomRC Exceed 500mw Mini VTX (included)
Antenna (included)
Available soon at Banggood
Available for orders on https://m.banggood.com/ATOMRC-FIXED-WING-Dolphin-p-1758430.html?p=!X1417487447201403QO - referal link
Will update as soon will have more information.
Oct 21, 2020, 01:52 AM
Racer.Lt Owner
Frimen's Avatar
The FPV version is awesome but goPro nose is like a brick
Oct 24, 2020, 11:41 PM
G-LO's Avatar
Hey, thanks for starting this thread. I was wondering if Alishanmoa started his own being that he was the first person to introduced it.
My brother just ordered one. I think it's a nice looking little plane. As soon as my brother's plane gets here, I'll decide if getting a already crowded hangar is worth it.
Nov 02, 2020, 10:38 AM
INAV
Olivier_C's Avatar
Oy! ordered one , will probably make some build videos.
Already got most of the electronics, Runcam Hybrid HD, emax servos, analog VTX, ESC 50A 7S, motor Emax RS2306 2750kV, this plane will go beyond 200km/h or will explode in a ball of fire trying
Nov 03, 2020, 07:37 AM
Racer.Lt Owner
Frimen's Avatar
I think it's for sure capable to do > 200km/h
Nov 03, 2020, 08:43 AM
Was just coincidentally looking at this earlier. I want it if it'll really go fast. Need to get it in the CZ warehouse though....
Nov 03, 2020, 09:30 AM
INAV
Olivier_C's Avatar
I would not be surprised if it's noticably faster than my Dart 250, since it has the ability to carry much bigger lipos, and the 2306 class motors are way less fragile than the 1306 / 1407 / 1806...
Also it appear to be pretty streamlined, with reasonnable stabs and not overly large wing tip cambers.
With a tri 4" and 4S and this motor I expect 200-210km/h, time will tell
Nov 04, 2020, 02:37 AM
It's a good looking plane... And is it really likely to be 6S capable? If so, what size?
Thinking of picking up a couple lipos et al from Hobbyking, with their %10 sale...
ps Also, what KV for a 2306 motor? Ideally, I would actually prefer 5S 2200s over 6S, since I have them...
Nov 06, 2020, 01:26 AM
INAV
Olivier_C's Avatar
All planes are 5S or 6S capable, just have to choose the motor and ESC and prop wisely !
I'm going for a 2306 2750kV, that's fairly high because I plan to go with 4S-1300 to 4S-2200, and maybe something like a 5S-1500 for fun at some point in the future. But 2750kV for 6S is too much, unless fitting a tiny prop like a 4" bi or a 3" tri.
If you plan to go 6S I think the proper kV is in the 1600-2100 range maybe ?
Nov 06, 2020, 01:31 AM
I would much rather stick with 4S and 5S like you, as I have a wide range of lipos in 4S and 5S, but not 6S. I have lots of 4S 1300s, but also 1500s, 1800s, 2200s, etc.. And 5S 1500s, 1800s, and 2200s... So if this thing ever makes it to the CZ warehouse, and I will check back and copy your motor choice... Thanks..
ps I also have a bunch of spare 40a, 50a, 60a, and 80a ESCs.. Lots of 6x4 or 6x6 props too, and oh yeah TONS of 5-inch race quad props(2-blade and 3-blade..)
I think I could even yank a Multistar Viking motor 2208 2600kv motor from my (incredibly stupid waste of time) foam-board F-35... How would that motor do? It shreds in my Z-84 on 4S with a 3-blade 5-inch race prop (5152 I think..) I don't mind buying another motor though if need be...
Nov 06, 2020, 01:45 AM
I have been looking at this one also, for once a plane of this size that doesnt look as a barn door at the front with a fpv camera in the nose.
Nov 06, 2020, 01:52 AM
It is a nice looking plane... Wish it were about %30 bigger...
I fly primarily LOS, and I am finding as they get faster, planes up to about 1200mm are just too small to be able to really get the enjoyment out of the speed. Three seconds of WOT, then you have to pull up in order to still be able to see it..
((FPV is still just Chinese to me..(no pun intended..) This antenna on the plane, that antenna (no, I mean those antennas, plural...) on the goggles, no clue about FCs, etc etc.. And I just have not enjoyed my experience with it so far - broken feeds, limited range, etc.. I want a HD quality %110 reliable plug and play FPV experience. Not to be all tense hoping my feed doesn't go out, causing my plane to crash.. l'm just not into all the Macgeyvering that seems required... And anyway, I just like the aesthetics of LOS...))
Nov 06, 2020, 03:23 AM
Well you have missed a lot.....you can start with the ZOHD Kopilot for about 35 bucks and it has return to home also, then add fpv stuff fx dji HD goggles later on.
Although I have piloted a lot of different aircrafts IRL, the feeling you get with that first person view through the camera is outstanding. Try it.
Nov 06, 2020, 03:44 AM
I have… I have Skyzone V2 goggles and a bunch of different other little bits and bobs for FPV. I have just never trusted it… As I said, if it were 110% reliable , plug n’ play, and perfect HD quality, that would be something else. But I don’t know how to get that, at least without paying a huge fortune… The rest of it requires too much research and MacGyvering and it seems to constantly change every couple of months, so I just can’t be asked to try to keep up.
In any case, I like the looks of this plane and I’m sure I would enjoy it just fine LOS… So just waiting till they get it in the European warehouse.
Nov 06, 2020, 04:49 AM
INAV
Olivier_C's Avatar
2208 2600kV sounds good to me with 4S !
Thats the good side of having quads and planes, we have millions spares and all sizes of props and lipos and motors
My first flights should be with a light 4S-1300 (if it can balance) and probably a 6x4 so I'm sure there's enough grip, and then I'll see from there.
New Product Sonicmodell AR Wing Pro 1000mm Wingspan EPP FPV Flying Wing RC Airplane KIT/PNP - KIT scousethief Flying Wings 4 Oct 21, 2020 06:38 AM
Discussion Great Simple, Fast, Cheap, Chuck-in-your-Car Park Flier - Wing Wing Z-84... Herrsavage Flying Wings 11 May 30, 2019 10:41 AM
Discussion Wing Wing Z-84 845mm Flying Wing--Seeking Reviewer BG Tobey Flying Wings 12 Oct 17, 2016 01:53 AM
Discussion Cheap Fast Wing under 30" mt_100 Flying Wings 12 Feb 08, 2016 11:04 PM
