Here are some pics. Is it is a V2 board. |
Wauw im so happy, im gonna try the BETAFPVF411 BEFH firmware and see how that runs. |
ah man, thank you so much. I installed a Matek F411 firmware on it and it runs great now. Ah im so happy.
I installed an old betaflight version because i read somewhere that this FC was nog compatible with the latest version of betaflight? So i installed version 3.2.5, at first it seem to want to explode haha but then saw that i did not had the motors reversed. After that it all works great. Im so happy that it runs that im a little bit afraid to tweak other settings haha. It is still at Dshot125 4K 2K haha im afraid that when i change it all it wil run rubbish again like when i started. I guess im gonna make a lot of backups with this settings. Ah i found the article again that says something about betaflight 4.x.x http://support.betafpv.com/support/s...a-brushless-fc Quote:
And the last question, what is the difference between the firmwares BETAFPVF411 and MatekF411 ? |
So i installed the latest BEFH BETAFPVF411 4.2.4 firmware
After flashing when i connect to BF i get the message that says something like: that there is a config for this model do u want to add this config or something. After that, i see that the config did not reversed motors. Also when i try the quad does not respond to stick imput. Only after adding theese CLI command i could get it to run: Code:
This Cli DIFF can be used for betaflight_4.1.X_BEFH/BETAFPVF411(STM32F411) on Beta85X 3S whoop (For F4 AIO 12A FC V2.0) name x series beacon RX_LOST beacon RX_SET serial 1 2048 115200 57600 0 115200 aux 0 0 0 1700 2100 0 0 aux 1 1 1 1300 1700 0 0 aux 2 2 1 1700 2100 0 0 aux 3 28 2 900 1300 0 0 aux 4 35 2 1700 2100 0 0 vtxtable bands 5 vtxtable channels 8 vtxtable band 1 BOSCAM_A A FACTORY 5865 5845 5825 5805 5785 5765 5745 5725 vtxtable band 2 BOSCAM_B B FACTORY 5733 5752 5771 5790 5809 5828 5847 5866 vtxtable band 3 BOSCAM_E E FACTORY 5705 5685 5665 5645 5885 5905 5925 5945 vtxtable band 4 FATSHARK F FACTORY 5740 5760 5780 5800 5820 5840 5860 5880 vtxtable band 5 RACEBAND R FACTORY 5658 5695 5732 5769 5806 5843 5880 5917 vtxtable powerlevels 4 vtxtable powervalues 0 1 2 3 vtxtable powerlabels 25 200 500 800 set gyro_lowpass2_type = PT1 set mag_hardware = NONE set baro_hardware = NONE set rssi_channel = 16 set fpv_mix_degrees = 35 set serialrx_provider = SBUS set blackbox_device = NONE set min_throttle = 1070 set dshot_idle_value = 450 set use_unsynced_pwm = OFF set motor_pwm_protocol = DSHOT600 set ibatv_scale = 400 set yaw_motors_reversed = ON set small_angle = 180 set pid_process_denom = 1 set osd_warn_core_temp = OFF set osd_vbat_pos = 2433 set osd_rssi_pos = 2242 set osd_tim_2_pos = 2455 set osd_flymode_pos = 2425 set osd_throttle_pos = 2369 set osd_crosshairs_pos = 2253 set osd_current_pos = 2400 set osd_mah_drawn_pos = 2392 set osd_craft_name_pos = 2442 set vcd_video_system = NTSC set p_pitch = 55 set i_pitch = 85 set d_pitch = 29 set f_pitch = 96 set p_roll = 48 set i_roll = 80 set d_roll = 27 set f_roll = 96 set p_yaw = 60 set i_yaw = 77 set f_yaw = 100 It seems to work now. Are theese the right commands? |
Once you flash a new version of BF it sets everything to default values. You have to then do a setup from scratch or paste in a CLI dump like you did. If it works like it should you are good to go. Fly as is or customize from there. Since that is a 4.1.x dump and you are running 4.2 you should probably set the pids back to default and tune from there or find a tune specific to 4.2. But if it flies fine and you are happy with it, dont fix it if it aint broke.
Thread Tools | |
Similar Threads | |||||
Help! | What do I have and what do I need to get these two 2m sailplanes in th air | pval3 | Electric Sailplanes | 18 | Mar 13, 2017 02:26 PM |
Question | DX8 Version - How Can I Tell What Version I Have? | MIGPILOT44 | Radios | 8 | Nov 24, 2016 03:46 PM |
Discussion | I have phantom guts what can I do with them | bcredneck | Multirotor Drone Talk | 5 | Jun 04, 2016 04:32 AM |
Discussion | MK Blue Angel 60 - what "version" do I have, 1973 WC version? | bossee | Classic Pattern Flying | 25 | Feb 09, 2012 08:51 PM |
