Oct 17, 2020, 08:55 PM
TTN
TTN
Design & Build <3
TTN's Avatar
160mm jetski impeller 3D scan file: attached
Got this scanned when we did some stuff at work, sharing here in the hope that someone finds it useful as a reference for further work.
Top of the blades is all there, and one side of the hub profile, bottom of blades is missing but should be enough to work off.
Oct 28, 2020, 07:51 PM
TTN
TTN
Design & Build <3
TTN's Avatar
Made it into a 39.0mm diameter impeller for a 40mm diameter pump model. STL and STEP file attached. Blade thickness is 1.3mm. Shaft hole diameter is 5.0mm. Hub diameter is 19.2mm.
Discussion Scanned binary STL files show up in slicer with gaps metalguy 3D Printing 1 Aug 23, 2016 03:40 AM
Discussion File Attachments PeteMenter Test Forum 3 Jun 10, 2016 10:32 AM
Suggestion Attaching DXF files v3r73x Site Suggestions / Complaints 2 Sep 29, 2015 06:07 PM
Discussion HET-6904--issues with collet attachment of impeller Rube Goldberg Electric Ducted Fan Jet Talk 41 Oct 28, 2008 02:13 PM
Discussion Alfa EDF - Attaching Impeller issue gliew Electric Ducted Fan Jet Talk 4 Jul 18, 2008 12:53 PM
