Oct 17, 2020, 07:33 AM
I Used To Have More Free Time!
Removing CA from film covering
Is there a way to remove CA that is on my film? I believe it is Oracover.
I accidentally spilled some when installing my CA hinges. I have some CA debonder, but thought it might eat the color off.
Oct 17, 2020, 08:02 AM
San Antonio TX.
sensei's Avatar
Put some on the bottom someplace, wait for a while and see what it does, I have used acetone on Monokote for years with no ill effect.
Bob
Oct 17, 2020, 09:34 AM
Team Extreme Flight
Doc Austin's Avatar
Orakote is pretty resistant to chemicals. I use lacquer thinner to clean the covering glue off the plane when the build is done, so it's pretty tough material.
I'm not a great builder and I usually spill a little somewhere. I use Golden West Super Solvent and it rips CA off like magic. Tower sells it as "hot stuff solvent," but you can get it at wood working stores and even Amazon.
I've also tried acetone, which works, but not nearly as well. There's a lot of acetone in nail polish remover, so you can try that if you are in a pinch.
Latest blog entry: Extreme Aviation Has A New Home
Oct 17, 2020, 09:49 AM
I don't want to "Switch Now"
pmackenzie's Avatar
The colour is on the inside, so as long as you stay away from seams the de-bonder will not affect the covering.
Oct 17, 2020, 09:59 AM
Great advice guys... Thanks much. I will report back when I decide which route to take.
Oct 17, 2020, 06:06 PM
I have used debonder with no problems. It is slow and can use more than one application.
Oct 17, 2020, 06:35 PM
I used the debonder... it did take a couple of applications, and then I cleaned off the residue with denatured alcohol. Thanks again.
Oct 17, 2020, 10:39 PM
aka: A.Roger Wilfong
gnofliwr's Avatar
I've used acetone, debonder and GoofOff. They all work, but debonder works the fastest. I squirt them on a paper towel and wipe onto the glue.
That allows more control than squirting it on directly - after all, the glue got there by poor control when squirting it on the joint.
- Roger
Question Removing film covering from an ARF JKinTX Electric Plane Talk 8 Jul 29, 2013 02:46 PM
Discussion Removal of covering film heat activated glue from solid surfaces? Masterpiece Painting and Finishing Tips 7 Sep 19, 2011 08:33 AM
Question Removing residue of covering film from a composite surface? Masterpiece Painting and Finishing Tips 5 May 24, 2009 05:44 AM
Discussion Any Tips on Removing Epoxy from Covering Film. jnm2512 Electric Plane Talk 5 Aug 28, 2006 12:32 AM
Remove CA from covering? Xoltri Electric Plane Talk 8 Jan 20, 2003 02:46 PM
