This thread is privately moderated by j1e9f6f8, who may elect to delete unwanted replies.
Oct 15, 2020, 01:21 AM
bjw
bjw
Thanks for posting those photos. I have the same Proctor kit myself but not yet started building it.
I notice you have a Saito engine installed; what is the specific engine size?
Was wondering about the balance point. Will you need much nose or tail weight to get the
balance right? I have several Saito engines of dfferent sizes and also the 3-cylinder FA-120 size. The 3-cylinder is much heavier than the singles, hence my interest in how your balance point works out.
Oct 15, 2020, 06:41 AM
bjw, I have the Strutter powered with a Saito FG-14 which would be the same as a FA-82. I take off at half throttle, so a 62 would probably work and stay within the cowl, but I compromised because these birds swung a big prop and the FG-14 can easily handle a 15-4. I started out with my balance point at 3.5" using steel bar weighing a pound and a half mounted on the firewall as shown in the photos. I have since machined off 7 oz. and will probably take off an ounce or two more until it flies with the elevator at a more neutral position. Fuel tank is directly behind the firewall and the 3000MAH LiFe battery and ignition are as well. So, I may end up at 4"-4.25" til it's all said and done. I'm still in the adjustment phase having maidened it just last week.
Oct 16, 2020, 05:36 AM
great job
Oct 16, 2020, 07:07 AM
Thanks.
Oct 16, 2020, 07:24 AM
mike_o's Avatar
Very nice work!
But how about taking realism one step further and let the dynamo actually work and replace the batteries?
Oct 16, 2020, 04:41 PM
Ha, it might be easier to use the air pump to pressurize the fuel tank!
Build Log Sopwith 1 1/2 Strutter IPS, plan P.Rake awiatik Scale Kit/Scratch Built 16 Oct 11, 2015 01:48 AM
Build Log Manzano Laser Cut Rake Sopwith 1 1/2 Strutter Build Log JMBRAD Scale Kit/Scratch Built 133 Oct 08, 2009 08:01 AM
Peter Rake Sopwith 1 1/2 Strutter JIMA Scale Kit/Scratch Built 241 Jun 24, 2005 10:59 PM
Question Sopwith 1 1/2 Strutter - Dale Tattum Design Verticallanding Scale Kit/Scratch Built 11 Mar 17, 2004 10:23 AM
Sopwith 1 1/2 Strutter Plans Dorme Scale Kit/Scratch Built 3 Nov 26, 2003 08:04 PM
